Self registration - terms of use failure
  • 1.  Self registration - terms of use failure
    Posted Jan 19, 2023 06:03 AM
    We're having an issue regarding email self registration on ClearPass Guest.
    The following error appears (image attached) regardless of the settings within the self-reg config and the form associated with the self-reg landing page (guest_register).
    I have tried the following:
    -Disabling the 'terms of use' field on the guest_register form.
    -Removing the field.
    -Enabling the field but having it hidden.
    -Have tried with the 'require terms of use' option deselected in the self-reg config.
    Any ideas? Ideally we would like to have this option deselected and users can log in without having to check a tick box. At the moment neither seem possible.
  • 2.  RE: Self registration - terms of use failure
    Posted Jan 20, 2023 07:35 AM
    Hi, can you share the images of the config in clearpass ?
  • 3.  RE: Self registration - terms of use failure
    Posted Jan 26, 2023 11:36 AM
    With the following changes to the creator_accept_terms field (in the guest registration form), it works for me:
    And under Advanced:
    Hope that helps?
