Self-registration using SMTP to SMS gateway
  • 1.  Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 10:59 AM
    Hi ,
    I am not sure if this is possible but what we want to test is to use an smtp to sms gateway to send the users self-registration credentials sms.
    So basically the self-registration portal will require the users Name, Surname, Company and mobile number and then send the self-registration receipt to an email address that is formulated from the mobile number field and a predetermined email domain i.e 0776612341234@email.com
    Can any one advise if it is possible and if so how?
    Many thanks
    Andy
  • 2.  RE: Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 11:02 AM
    This is all built in to ClearPass Guest. Take a look at page 348 in the CPG 6.3 User Manual.
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=12979
  • 3.  RE: Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 11:08 AM
    I kind of figured it was but not sure what to do to make it work.
  • 4.  RE: Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 11:15 AM
    First enable the mobile carriers you want to list under:
          Guest | Administration » SMS Services » Mobile Carriers
    In your guest registration form, enable (or add) the "visitor_carrier" field and make sure it is visible.
    Then enable (or add) the "auto_send_sms" field and make the sure the initial value is set to 1.
    Under configuration » SMS Receipt, match the fields:
         Phone Number Field: visitor_phone
         Auto-Send Field: auto_send_sms
    If you want to customize the SMS receipt text, modify the "SMS Receipt" template under Configuration » Print Templates.
  • 5.  RE: Self-registration using SMTP to SMS gateway
  • 6.  RE: Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 11:48 AM
    thanks cappalli and tarnold this looks like the stuff i was looking for.
  • 7.  RE: Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 12:22 PM
    Another question,
    I assume the text "NUMBER" in the email address get replaced by the text in the visitor_phone field in the SMS template and send via the mail server in the messaging setup on the plocy manager.
  • 8.  RE: Self-registration using SMTP to SMS gateway
    Posted Feb 07, 2014 02:41 PM
    It works and I am so happy now as hopefully the customer will finally throw his "ICE" server in the trash
    :smileyvery-happy:
