Send Alert When a Rogue AP is Connected to the LAN
  • 1.  Send Alert When a Rogue AP is Connected to the LAN
    Posted Jan 11, 2013 09:32 AM
    I'd like to get an alert when a Rogue AP is classified as "Detected Wirelessly and on LAN". I thought about creating a trigger for it, but it isn't obvious to me how to configure it for this. How would you do this?
    Robert
  • 2.  RE: Send Alert When a Rogue AP is Connected to the LAN
    Posted Jan 11, 2013 09:57 AM
    You might check the "Setting Triggers for IDS Events" on Airwave User Guide ( its in page 211 on Airwave 7.5 UG).
    Goodluck!
  • 3.  RE: Send Alert When a Rogue AP is Connected to the LAN
    Posted Jan 11, 2013 11:06 AM
    Thanks. I'd looked over that. The rules under RAPIDS all have a threat level of 5. I bumped the rule for Rogues on the LAN to threat level 6 and made a trigger based off the threat level. I'll see how that works.
  • 4.  RE: Send Alert When a Rogue AP is Connected to the LAN
    Posted Jan 11, 2013 02:59 PM
    It looks like another option would be to create a report that runs regularly with the option "New Rogue Devices: Devices Discovered on the LAN Only" reported. I'll try that too.
    Robert
  • 5.  RE: Send Alert When a Rogue AP is Connected to the LAN
    Posted Jan 14, 2013 02:59 PM
    I know that you can setup an email alert...I am seeking to be able to generate/send via syslog or SNMP Trap.  Any information would be appreciated.
  • 6.  RE: Send Alert When a Rogue AP is Connected to the LAN
    Posted Jan 14, 2013 05:23 PM
    The controller will do that by default (send SNMP traps and syslog).  In Airwave you can also forward to an NMS in a trigger.
