I want to send the logoff-period through a DUR from ClearPass to a ArubaOS switch. This setting is configurable at the switch for a role but how do I need to put inside a HPE-CPPM-Role??
This is not currently supported in Standard mode but I haven't had a chance to test Advanced mode.
Hello Tim,
I also go testing with it on the advanced mode.
Maybe when I get the syntax right it works.
Let me now if you get it to work
At the moment it is possible to do it inside clearpass with the normal DUR configuration. So no need anymore for the advanced config
