Sending H3C terminate session disconnect wired telephone
  • 1.  Sending H3C terminate session disconnect wired telephone
    Posted Mar 20, 2019 11:25 AM
    Hi
    I have scenario where I have Avaya phones with laptops in daisy chain
    All together they are authenticating via ClearPass: ip phone via MAC-auth, laptop via 802.1x.
    because I'm deploying OnGuard i send terminate session after health web-based policy, defualt [H3C Terminate session]
    After sending this telephones are disconnecting from switche port
    After some investigation I have found in log for that session that ther'is error in ClearPass to find propoer attributes to send in [H3C Terminate Session]
    In logs I have found:
    WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Radius:IETF:User-Name}, error=No values for param=Radius:IETF:User-Name
    WARN Core.PETaskRadiusCoAEnfProfileBuilder - addParamsFromParameterizedProfile: Failed to find finalValue for name= Radius:IETF:User-Name value = %{Radius:IETF:User-Name}. Searching attributes from battery
    WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Radius:IETF:Calling-Station-Id}, error=No values for param=Radius:IETF:Calling-Station-Id
    WARN Core.PETaskRadiusCoAEnfProfileBuilder - addParamsFromParameterizedProfile: Failed to find finalValue for name= Radius:IETF:Calling-Station-Id value = %{Radius:IETF:Calling-Station-Id}. Searching attributes from battery
    I suspect that this session ternation doesn;t work as expected and terminate all sessions on port, so my phone dosconnect
    The switch is Comware HPE 5130 HI
    Someone have similar problem ?
    regards
    Karol
  • 2.  RE: Sending H3C terminate session disconnect wired telephone
    Posted Mar 20, 2019 11:27 AM
    That means there is no active RADIUS session for the device.
  • 3.  RE: Sending H3C terminate session disconnect wired telephone
    Posted Mar 20, 2019 11:31 AM
    Hi
    So what You could recommend to work termination only for laptop ?
    Karol
  • 4.  RE: Sending H3C terminate session disconnect wired telephone
    Posted Mar 20, 2019 11:55 AM
    No, you need to see why there is no RADIUS session for the device you’re trying to disconnect.
  • 5.  RE: Sending H3C terminate session disconnect wired telephone
    Posted Mar 26, 2019 11:46 AM
    Hi
    I had made packet capture from ClearPass and Radius debug from the comware switch and I found that CPPM send valid use-rname and MAC-address (Calling-Station-Id) to terminate session to switch port.
    But still don't know why IP telephone disconnect,
    I enclose I packet capture dump
    I have logged case in HPE support for the switch
    regards
    Karol
  • 6.  RE: Sending H3C terminate session disconnect wired telephone
    Posted Mar 26, 2019 05:30 PM
    Alternatively you could use the bounce client option in the agent enformcent to perform a bounce from the client.
  • 7.  RE: Sending H3C terminate session disconnect wired telephone
    Posted Mar 26, 2019 06:02 PM
    Hi Fabian
    I have already reconfigured it to agent bounce port, but I thought about it rather as temporary solution, but maybe It will be the only solution for me
    regards
    Karol
