Seperate AP from the same Virtual Controller
  • 1.  Seperate AP from the same Virtual Controller
    Posted Sep 12, 2017 10:48 AM
    Gurus,
    I've an issue whereby some of my IAP is joined to same VC even its in different subnet
    how to seperate them into differnet VC?
    the network is already /24.
    my other issue is, one of the AP is the same cluster will always up and down (even its actuall up in the real world, only in central down)
    when this occured, AP 1 will up in central, AP 2 will down in central and vice versa.
  • 2.  RE: Seperate AP from the same Virtual Controller
    Posted Sep 16, 2017 09:06 AM
    I believe you need to provision the AP's in separate groups in Aruba Central.
