Serial Breakout cable problem
  • 1.  Serial Breakout cable problem
    Posted Sep 25, 2014 09:04 PM
     I have been trying to create my own serial breakout adaptor but am having no sucess.
    The scale i have been following is base on the link shared in the achived post.
    http://community.arubanetworks.com/t5/Access-Points/Serial-Over-Ethernet-Breakout-Cable/td-p/991
    This is what i have done. Just wondering if i have misunderstood the way how it should be linked or something went wrong
    ** i am unable to power the AP up with this format but the AP works fine with just a cable linked to the power injector.
      1       2       3    4      5     6      7     8
    BR / WBR / G / WB / B / WG / O / WO    (To AP)
                        l                     l      l       l       (Links)
           /         / G /       /     / WG / O / WO    (To Network)
    Serial Port 2  - WBR
    Serial Port 3 - B
    Serial Port 5 - BR / WB
  • 2.  RE: Serial Breakout cable problem
    Posted Sep 25, 2014 09:06 PM
    What are you trying to console into?
  • 3.  RE: Serial Breakout cable problem
    Posted Sep 25, 2014 09:15 PM
    Hey there,
    That would be the older models AP such as AP65 which has only one ehernet port.
  • 4.  RE: Serial Breakout cable problem
    Posted Sep 27, 2014 11:22 PM
    Does anyone have any idea ? I know that the design works just that i might have screwed up the cabling. Does the color coding matter in this case ?
    Does anyone have a working design and is able to share with me the color connection ?
