SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
Serial number of Aruba-9004 Gateway via SNMP not showing
  • 1.  Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted 13 days ago
    I am trying to get the details (Model, Version, Serial#, etc.) of our SD-WAN gateways using SNMP. I used the snmpwalk tool to test the information available. I see that the agent outputs
    SNMPv2-MIB::sysDescr.0 = STRING: ArubaOS (MODEL: Aruba9004-LTE-US), Version 10.4.0.3 LSR (87961)
    However, I don't see the Serial number of the device in the snmpwalk output and I am puzzled.
    If needed, I can attach the snmpwalk output here.
    Any clues?
    -kd
  • 2.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted 13 days ago
    the latest LSR firmware for gateways is 10.4.1.1, so try tat if it works but generally you should get that info fro Aruba Central or using Central APIs,
  • 3.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted 13 days ago
    I would think the Serial# of the Gateway is very basic information that should have been present right from the first release. I also tried the Gateway UI and I still don't see the Serial# in the UI too.
    Where can I find the correct MIBs for these 9004 SD-WAN gateways?
    One more question: Do these Gateways support Redfish based management?
    Thanks for your help
  • 4.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted 12 days ago
    AOS10 gateways needs Aruba Central. So you can view the serial numbers from there.
  • 5.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted 12 days ago
    I figured out the issue and was able to get the serial number of the device. However, there's another anomaly in the SNMP output and I will create another post for that.
