SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
Serial number of Aruba-9004 Gateway via SNMP not showing
  • 1.  Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted Apr 17, 2024 02:21 PM
    I am trying to get the details (Model, Version, Serial#, etc.) of our SD-WAN gateways using SNMP. I used the snmpwalk tool to test the information available. I see that the agent outputs
    SNMPv2-MIB::sysDescr.0 = STRING: ArubaOS (MODEL: Aruba9004-LTE-US), Version 10.4.0.3 LSR (87961)
    However, I don't see the Serial number of the device in the snmpwalk output and I am puzzled.
    If needed, I can attach the snmpwalk output here.
    Any clues?
    -kd
  • 2.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted Apr 17, 2024 11:43 PM
    the latest LSR firmware for gateways is 10.4.1.1, so try tat if it works but generally you should get that info fro Aruba Central or using Central APIs,
  • 3.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted Apr 18, 2024 01:21 AM
    I would think the Serial# of the Gateway is very basic information that should have been present right from the first release. I also tried the Gateway UI and I still don't see the Serial# in the UI too.
    Where can I find the correct MIBs for these 9004 SD-WAN gateways?
    One more question: Do these Gateways support Redfish based management?
    Thanks for your help
  • 4.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted Apr 18, 2024 02:38 AM
    AOS10 gateways needs Aruba Central. So you can view the serial numbers from there.
  • 5.  RE: Serial number of Aruba-9004 Gateway via SNMP not showing
    Posted Apr 18, 2024 03:33 PM
    I figured out the issue and was able to get the serial number of the device. However, there's another anomaly in the SNMP output and I will create another post for that.
