Server 2008 (R2) and MAC Authentification
  • 1.  Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 01:54 AM
    Hi again,
    I try to configure my server 2008 to do MAC authentification ... I also use this server as logon server with mschap, this works great.
    My question is: can i use my radius server to do mac authentification and logon?
    I want to get the MAC-adresses out of my active directory...  is this possible?
    Thanks!
  • 2.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 02:27 AM
    Please try this technet article here:
    http://blogs.technet.com/nap/archive/2006/09/08/454705.aspx
  • 3.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 02:43 AM
    If i klick on this link i get an Outlook Web App- Page ....is that correct?
    I found that link before but i always get this...
  • 4.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 03:12 AM
    I fixed the link.  Not sure why it was doing that...
  • 5.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 03:16 AM
    Sorry but is this the right link? Title is "Certificate Autoenrollment in Windows XP"?!
  • 6.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 03:36 AM
    No.  lets try this one more time:
  • 7.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 03:51 AM
    Thanks!
    This solution is not the best for our constellation... Is it possible to let the aruba controller check if a mac-adress is in the active-directory and then do the MSCHAP-Logon?
    Sorry for the bad english.
  • 8.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 04:03 AM
    The general answer is yes.  You can create  mac authentication profile and mac authentication server group in the same AAA profile that you do 802.1x
    The big question is: do you already have all of these mac addresses stored somewhere?  The issue is adding/deleting and maintaining the mac addresses either as users in Active Directory or Users in the local database on the controller.
  • 9.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 06:58 AM
    No.
  • 10.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 07:05 AM
    Okay.  The instructions to configure mac-based authentication is here:  How do I configure MAC-based authentication on Aruba? https://kb.arubanetworks.com/app/answers/detail/a_id/1126
  • 11.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 07:16 AM
    Thanks for your reply.
    This works... i have tested it before ... but now i dont want to save the mac adresses in the internal database but in the active directory.
    Is this possible?
  • 12.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 07:17 AM
    You can configure a user in AD with the username and password being the mac address.  in your AAA profile, the MAC authentication server group will then be your AD radius server.
  • 13.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 07:20 AM
    I tested that yesterday... reason was:
    the user "00-1C-AB-XX-XX-XX@domain.local" tried to logon at the radius server...is that correct?
  • 14.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 07:28 AM
    Yes.
  • 15.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 11, 2012 08:40 AM
    Thanks! It works!
    But I have got a problem... if i want to connect to my network i can also do this while typing in the mac-adress as username and password -  not using the correct username.
    I hope this is comprehensible for you.
  • 16.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 12, 2012 05:50 AM
    ....okay I fixed this by creating a second rule on my radius-server.
  • 17.  RE: Server 2008 (R2) and MAC Authentification
    Posted Jul 12, 2012 06:10 AM
    Very good.  Please mark the thread solved..
