Server-Derivation roles and Aruba Instant
  • 1.  Server-Derivation roles and Aruba Instant
    Posted May 04, 2012 06:50 PM
    Can you use server-derivation for user roles in Aruba Instant?
    Specifically, is there a way to say if a mobile device matches it's DHCP ID it will assigned the "mobile-role", or whatever role you want assigned to it?
    Or, if a user is in a particular OU in AD it will be assigned a specific role?
    I know I can do this in Aruba OS, but don't know if it can be done with Instant.
    Thanks.
  • 2.  RE: Server-Derivation roles and Aruba Instant
    Posted May 08, 2012 01:35 AM
    Yes with the new version of Instant (3.0) you can do role derevation based on RADIUS attributes from your AD user group.
    -Ariya
