Server-derived rule using Filter-Id from FreeRADIUS not working
  • 1.  Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 13, 2017 11:28 AM
    I'm setting up a wireless lab. I added FreeRADIUS 3.0.15 to my back-end services. I am trying to set up a server-derived rule. The intent is that when guest123, password guest123 authenticates via 802.1X, radius1 (the FreeRADIUS server) returns Filter-Id = labguest, and a rule in the server group containing radius1 sets the user-role to labguest instead.
    What happens instead is that the user receives the default 802.1X role, "authenticated".
    Here is the relevant Aruba configuration:
    user-role labguest
     access-list session global-sacl
     access-list session apprf-labguest-sacl
     access-list session dont-ping-controller
     access-list session allowall
     access-list session v6-allowall
    aaa authentication-server radius "radius1"
       host "192.168.18.249"
       key b07f6475f2dcdf6f66ef027b4532fe8b8fb1b5880e755383
    aaa server-group "lab-emp_srvgrp-ckl54"
     auth-server radius1
     set role condition Filter-Id value-of
    The following looks good:
    (Master1) #aaa test-server mschapv2 radius1 guest123 guest123 verbose
    Authentication Successful
    Processing time (ms) : 2.589
    Attribute value pairs in request
    Vendor     Attribute           Value
               NAS-IP-Address      192.168.18.254
               NAS-Port-Id         0
               NAS-Port-Type       Wireless-IEEE802.11
               User-Name           guest123
               Service-Type        Login-User
               Calling-Station-Id  0.0.0.0
               Called-Station-Id   000B86BE91F0
    Microsoft  MS-CHAP-Challenge   ,W\332\023\211\277R@c\350\262\333\031\270w\017
    Microsoft  MS-CHAP2-Response
    Aruba      Aruba-Essid-Name
    Aruba      Aruba-Location-Id   N/A
    Aruba      Aruba-AP-Group      N/A
    Aruba      Aruba-Device-Type
               Message-Auth        \263if&\273\027\236y\034:4\270E\372\262\234
               PW_RADIUS_ID        \360
               Rad-Length          199
    Attribute value pairs in response
               Filter-Id                  labguest
    Microsoft  MS-CHAP2-Success
    Microsoft  MS-MPPE-Recv-Key           \202\336
    Microsoft  MS-MPPE-Send-Key           \215\270Q\230"\0048\252\301\\377\313b\001\024\360\202u\350\033\217\322Q\025L\365ri\201\340sY\347\011
    Microsoft  MS-MPPE-Encryption-Policy
    Microsoft  MS-MPPE-Encryption-Types
               PW_RADIUS_ID               \360
               Rad-Length                 189
               PW_RADIUS_CODE             \002
               PW_RAD_AUTHENTICATOR       \347\211\010\362\356\232\017\011\246$\351\314\365\271\370\350
    The same thing results from the Local1 controller, since both Master1 and Local1 were set up as RADIUS clients at FreeRADIUS.
    But when guest123/guest123 authenticates via 802.1X, the user-role is "authenticated", when it should be "labguest":
    (Local1) #show user mac 44:39:c4:59:e5:64
    Name: guest123, IP: 192.168.17.37, MAC: 44:39:c4:59:e5:64, Age: 00:00:00
    Role: authenticated (how: ROLE_DERIVATION_DOT1X), ACL: 70/0
    Authentication: Yes, status: successful, method: 802.1x, protocol: EAP-PEAP, server: radius1
    Authentication Servers: dot1x authserver: radius1, mac authserver:
    Bandwidth = No Limit
    Role Derivation: ROLE_DERIVATION_DOT1X
    ...truncated output
    Just in case this is a FreeRADIUS issue, I also posted the same issue at https://stackoverflow.com/questions/47681051/server-derived-role-based-on-filterid-using-freeradius-not-working
    Thoughts?
  • 2.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 13, 2017 11:29 AM
    Why are you using filter-id with SDR? Just return the Aruba-User-Role VSA directly.
  • 3.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 13, 2017 02:14 PM
    I'm preparing for a certification with a non-disclosure agreement, so I can't tell you exactly what I'm attempting to solve.
    However, my setup is also ignoring Aruba-User-Role VSA. I believe an Aruba VSA is supposed to be top priority.
    This works:
    Processing time (ms) : 3.909
               NAS-Port-Id         0
               User-Name           guest123
    Microsoft  MS-CHAP-Challenge   \207M>\205\367"[\032\204\304\307^\272k\251\317
               Message-Auth        q\267M\203\016\375\324v]\205\261\2678\020\016Y
               PW_RADIUS_ID        \361
               Rad-Length          199
    Aruba      Aruba-User-Role            labguest
    Microsoft  MS-MPPE-Recv-Key           \206\254\177+\233\010n_\265p\275\333R\011(4\215'\264]\003MEq\204\0064B\340\033\326\244U\322
    Microsoft  MS-MPPE-Send-Key           \217\032\251\256\032\230_%\373\32687BF\260dn\305\350\235\246\002\341E\355\317\032\021\277\311I!\246'
               PW_RADIUS_ID               \361
               Rad-Length                 195
               PW_RADIUS_CODE             \002
               PW_RAD_AUTHENTICATOR       3\341\3629\237\242\242 b\3631\372\252\021
    But when guest123/guest123 authenticates, user-role is still "authenticated":
    (Master1) #show user mac 44:39:c4:59:e5:64
    VLAN Derivation: Default VLAN
  • 4.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 13, 2017 02:19 PM
    That role definitely exists on the controller?
  • 5.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 13, 2017 02:21 PM
    Yes. Here it is:
    user-role labguest
  • 6.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 14, 2017 07:38 AM
    I think something may be funky about the exchange with my RADIUS server.
    I can show you some logs, if you advise which ones to set up prior to authenticating.
  • 7.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 15, 2017 11:26 AM
    I believe I have a broken lab, in some regard. Here's what I've done to continue to troubleshooting it.
    Questions: is the RADIUS server behaving properly, from the logs and packet captures? I do see it sending back the AVP "FilterId","labguest" in one of the packets, but not in the accept packet at the end. Should it be there as well? Can someone please do a simple test with a working setup and compare?
    I attach resulting logs, and RADIUS traffic screenshots from Wireshark.
    Other notes:
    I did a fresh build -- write erase all and set up just the master, AP, switch, and back-end services.
    Added radius1 with the correct host IP and key.
    Created ACL "dont-ping-controller".
    Created user-role "labguest" designed to allow the user to do everything but ping the controller.
    Used wlan wizard to make an 802.1X VAP. There was a checkbox to set up SDR based on Filter-Id, so I used it.
    Here's the relevant part of the resulting config:
    user-role labguest
       key fb11664b1c366e5eca38c6f86a95cd0b34ee938842c55450
    aaa server-group "Lab-Emp_srvgrp-zud62"
     auth-server radius1
     set role condition filter-id value-of
    I notice the code generated by the wizard referred to "filter-id" rather than "Filter-Id". I changed it at the CLI as follows, but it still didn't help. Since Aruba VSAs are also being ignored, that can't be the sole issue in any case.
     auth-server radius1
    ***This is bad***
    (Master1) # show user mac 44:39:c4:59:e5:64
    ***This is good***
    Processing time (ms) : 6.301
               NAS-Port-Id         0
               User-Name           guest123
    Microsoft  MS-CHAP-Challenge   \220\024\274\330\2622FP\351\025c\234\234\256Bv
               Message-Auth        \223.1\222\034n\362E\224\217\307\371\211\237\3527
               PW_RADIUS_ID        E
               Rad-Length          199
               Service-Type               Framed-User
               Filter-Id                  labguest
    Microsoft  MS-MPPE-Recv-Key           \307\354$s\277c\215\262|\246\312F\216\275\025v\032\305K\212\271J\370+\225#\314*i\324\321\001
    Microsoft  MS-MPPE-Send-Key           \3137\217\0117<\001#L\212\177\303\023\356\374("\016d#\017\217+a\022\311\214B\273;\260\256V\004
               PW_RADIUS_ID               E
               Rad-Length                 195
               PW_RADIUS_CODE             \002
               PW_RAD_AUTHENTICATOR       \274\335\332\250~*\2647\253\321\210\370\016aA.
    Attachment(s)
    txt
    logs - SDR.txt   63 KB 1 version
  • 8.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 15, 2017 03:09 PM
    I attach Wireshark screenshots and controller logs. Still not working. Can anyone tell if the exchange with RADIUS is right?
    Attachment(s)
    txt
  • 9.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 15, 2017 06:17 PM
    Please work with Aruba TAC. Troubleshooting is difficult on here.
  • 10.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 16, 2017 11:11 AM
    Have you tested with an actual wireless client?  The SDR rules are applied to the server-group, but the aaa test is done by specifying a server.
  • 11.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Dec 18, 2017 07:36 AM
    I connect wirelessly to SSID Lab-Emp. It prompts for username and password, does 802.1X authentication based on radius1 which is in the group with the SDR. RADIUS returns Filter-Id labguest and accepts the authentication request. The user is then connected but with the role "authenticated" rather than "labguest". I tried both from the laptop, and from a Samsung phone.
    On the other hand, I set up another SSID called Lab-Guest using captive portal and radius1 with the same SDR in the server group. guest123/guest123 does receive the role "labguest" after captive portal (L3) authentication. Just not when authenticating L2/802.1X.
    I won't hammer this board, based on Tim's feedback. I'll open a case at TAC, but still check here from time to time. I think someone may have an idea what's going on.
    Thanks all!
  • 12.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Jan 11, 2018 12:39 PM
    I would like to provide closure:
    This turned out to be a FreeRADIUS configuration issue.
    Aruba support engineer Akshay Sharma analyzed captured packets and observed:
    I would like to inform you that I went through the packet captures and I have attached the screenshots from the same based on what we observed; As seen in the CP-Accept screenshot, we see the Radius Accept, for when the user was authenticating with Captive Portal. We see in the accept packet, that the server is sending the attribute 'labguest' to the controller for the user role to be assigned. In the case of Dot1x-Accept screenshot, we do not see any attribute being sent by the server in the accept packet for when the user was authenticating with dot1x authentication. Please check on the server end if we need to enable sending attribute for MSCHAPv2 along with the PAP protocol, or if there are any specific configurations on the server that are handling the attributes to be sent based on the authentication type.
    I then posted to the FreeRADIUS user list, and received this feedback:
    “The solution is to move the "files" module to before "eap".  Edit sites-enabled/default.   Look at the "authorize" section.”
    SDR and Aruba VSAs now work fully with FreeRADIUS.
    The value to the community is that especially for wireless lab and proof of concept use, FreeRADIUS is a viable alternative to more costly or complicated RADIUS solutions.
    The configuration I used is:
    FreeRADIUS 3.0.15 / Ubuntu 16.04.3 / VMWare Workstation 14
    Set up a static IP by editing /etc/network/interfaces. Restart.
    Open UDP 1812 and 1813 at the laptop firewall.
    Edit users to add usernames, passwords, and returned attributes.
    Edit clients.conf to add controller(s).
    Update certificates.
    Edit sites-enabled/default as explained above.
    Start the service via "freeradius -X" to see debug output, or simply "freeradius". If it was already running, then stop it first by "service freeradius stop".
  • 13.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Feb 22, 2018 08:59 PM
    Thank you, thank you, thank you.  I've been struggling so long trying to figure out why my Aruba-VLAN tag was not working.  Move files before EAP solved the problem.
  • 14.  RE: Server-derived rule using Filter-Id from FreeRADIUS not working
    Posted Feb 23, 2018 05:17 AM
    This !
    Had trouble understanding exaclty what to do, but once I found the "authorize section" it was more clear. I had this exact problem yesterday aswell. Was setting up a lab with ArubaOS8 and using Aruba-User-Role. Couldn´t for my life understand why it wouldn´t work.
    Awesome that you took the time to post this follow up, thank you!
