type "show user ip" will only tell you if the client got its address from dhcp or not.
If you are running ArubaOS 6.x, you can do this:
configure t
logging level debugging network process dhcpd subcat dhcp
Allow the client to connect, then type "show log network 50" to see where the client got its ip address from.
