Service for authentication of F5 LTM with clearpass
  • 1.  Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 02:59 PM
    Hi
    I have a requirement , where i have to create a VIP at F5 LTM for our radius servers at Clearpass (publisher and suscribers). All the users will land to VIP IP for radius authentication in order to achieve load balancing b/w radius servers.
    when i crearted the VIP i am getting below error on clearpass:
    Error Code: 204
    Error Category: Authentication failure
    Error Message: Failed to classify request to service
    Alerts for this Request
    RADIUS Service Categorization failed
    Kindly help to create a service on Clearpass for the same...
  • 2.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:01 PM
    You need to look at the RADIUS request a create a service that matches the attributes.
  • 3.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:03 PM
    Are you doing SNAT at the F5? Please check the radius input attributes to see which attributes are send in the radius request. Compare this with the service rule filter
  • 4.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:09 PM
    I would like to know what Service should be created on clearpass in order to make authentication successfull from F5 LTM..
  • 5.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:12 PM
    As mentioned, you need to look at the RADIUS request and build matching service rules.
  • 6.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:18 PM
    here is the o/p from access tracker:
    Authentication:ErrorCode 204
    Authentication:Full-Username testuser
    Authentication:Full-Username-Normalized testuser
    Authentication:MacAuth NotApplicable
    Authentication:Posture Unknown
    Authentication:Status Failed
    Authentication:Username testuser
    Connection:Dest-IP-Address 10.xx.xx.xx
    Connection:Dest-Port 1645
    Connection:NAD-IP-Address 10.xx.xx.xx
    Connection:Protocol RADIUS
    Connection:Src-IP-Address 10.xx.xx.xx
    Connection:Src-Port 38829
    Date:Date-Time 2019-04-11 20:06:18
    Policies Used -
    Service: -
    Authentication Method: -
    Authentication Source: None
    Authorization Source: -
    Roles: -
    Enforcement Profiles: -
    Service Monitor Mode: Disabled
    Online Status: Not Available
  • 7.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:20 PM
    Have you added pap as a authentication method in the service? F5 is using pap for testing
  • 8.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:21 PM
    No, how can i do it ?
  • 9.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:24 PM
    In the clearpass service and than go to the authentication tab. Here you can add a auth method. Propably there is now EAP-PEAP. Please add PAP also here. I would advice to create a specific service only for F5 health checking because PAP is not secure
  • 10.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:29 PM
    i would also prefer to create a new service, is there any example template from where i can take reference in order to create a new service specific for F5 ?
  • 11.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:32 PM
    I don’t think there is a template in clearpass. Just create a service and filter on the NAS id of the F5 and the test user username.
  • 12.  RE: Service for authentication of F5 LTM with clearpass
  • 13.  RE: Service for authentication of F5 LTM with clearpass
    Posted Apr 11, 2019 03:13 PM
    Is this for health monitoring? If yes you need to use PAP authentication.
