Session Limits
  • 1.  Session Limits
    Posted Feb 09, 2015 08:56 AM
    Hi All,
    Another one.
    We have set the session limit on guest accounts to 1, thinking that this would limit the number of devices / logins to 1.
    Our client has tested and has been able to login to 2 device at the same time (and apparently browse on both).
    Is there a setting that I am missing?  Do I need to have an enforcement policy to disable additional devices / login attempts?
    TIA
    Gordie
  • 2.  RE: Session Limits
    Posted Feb 09, 2015 09:56 AM
    Do you have The endpoint db as an authorization source on your service ?
  • 3.  RE: Session Limits
    Posted Feb 11, 2015 05:33 AM
    Hi Victor, I am not sure. How would I check? TIA G
  • 4.  RE: Session Limits
    Posted Feb 15, 2015 07:50 AM
    check your authentication tab, what does it show? easiest just to post some screenshots of your clearpass service.
  • 5.  RE: Session Limits
    Posted Feb 18, 2015 05:49 AM
    Hi Victor,
    Please see attached.
    Let me know if you need anything more.  Thanks again for your help.
  • 6.  RE: Session Limits
    Posted Feb 18, 2015 05:54 AM
    Victor is looking for screen shot of the service tabs to see what you have for autentication, authorization, role and enforcement.
  • 7.  RE: Session Limits
    Posted Feb 18, 2015 10:38 AM
    Hi Troy,
    I have been through both policy manager and guest and cannot find the tabs that you have described.
    Where are they?  Sorry for being a noob :)
    G
  • 8.  RE: Session Limits
    Posted Feb 18, 2015 01:16 PM
  • 9.  RE: Session Limits
    Posted Feb 20, 2015 10:37 AM
    Thanks Danny,
    I will try and get a screen grab over the weekend, failing that it could be Monday.
    Just out of curiosity, should there be a tick or not in the Auth box?
    TIA
    Gordie
  • 10.  RE: Session Limits
    Posted Feb 20, 2015 05:50 PM
    Gordie,
    If you tick [select] the authz box then the authz TAB will appear and be availble for configuration.
