last person joined: 9 hours ago
Session Notification Enforcement not working for ASA Anyconnect
This thread has been viewed 27 times
  • 1.  Session Notification Enforcement not working for ASA Anyconnect
    Posted Sep 27, 2020 05:39 PM
    Hi there,
    I just setup a service to authenticate Cisco Anyconnect clients.
    Everything is working well except the "Session Notification Enforcement" I need.
    I want to call an external API when users connect and disconnect. I set the Session Notification Enforcement with the correct Context Server Actions, but ClearPass never seems to call those actions.
    Any idea what can be the problem?
  • 2.  RE: Session Notification Enforcement not working for ASA Anyconnect
    Posted Sep 27, 2020 07:54 PM
    My first thought for these type of scenarios is that we're not seeing RADIUS Accounting, this is needed on the session for the post-auth sess-notification to fire, are we getting accounting data?
  • 3.  RE: Session Notification Enforcement not working for ASA Anyconnect
    Posted Mar 02, 2021 06:31 AM
    Did you manage to get this working?
    Based on my research, the issue is that AnyConnect is not sending Calling Station ID as MAC address which is expected by ClearPass to trigger the update process. This was confirmed in one of my previous TAC cases - endpoint database is source of truth and MAC address is stored there. Instead AnyConnect is using IP address in Calling Station ID and that messes up the behavior. I don't think there is a way to change it on the AnyConnect/ASA side, but that is still being researched.
    Andris
  • 4.  RE: Session Notification Enforcement not working for ASA Anyconnect
    Posted Mar 02, 2021 12:38 PM
    In later versions {Note this was added this about ~2 years back} of anyconnect the mac-address is sent as a AV-Pair, back in a release in 6.8.x code train we added a feature to parse this and use it to help trigger situation like post-auth. Ensure this is enabled on your CPPM under..... Admin>Server manager>Server Config <chose your node/publisher> > Service Parameters > <choose Radius Server> > then scroll down to you see "Parse Cisco-AVPair to get device mac"
    HTH
    Danny Jump
    "Passionate about CPPM"
  • 5.  RE: Session Notification Enforcement not working for ASA Anyconnect
    Posted Mar 02, 2021 01:09 PM
    Oh, nice one, completely missed that option, thanks!
    As far as Windows goes, that is working as expected, but there seems to be one caveat with this on the Android - AVPair attribute that is being parsed by CP is "device-public-mac", but in case of AnyConnect for Android that AVPair is not present, instead there is only "device-mac" being sent, so that means we're getting this in the logs:
    INFO RadiusServer.Radius - rlm_service: device-public-mac= value not present in any of Cisco-AVPairs
    Don't know about Mac, will be tested.
    Tbh, this is not the first time this AnyConnect behavior is causing an issue as there is at least one MDM solution that requires "device-public-mac" to be present, but as AnyConnect is not passing that, it is causing an issue, but as far as I know - that is not something we can adjust.
    Have you considered to give ability adjust which AVPair value is taken into account?
    Andris
  • 6.  RE: Session Notification Enforcement not working for ASA Anyconnect
    Posted Mar 02, 2021 01:42 PM
    Adris,
    Glad that got you started. I suggest you reachout via your Aruba Partner/Aruba SE to raise a feature request for this, I'm no longer @ Aruba, just providing my knowledge here to help you all as a passionate ex Aruba CPPM Product Manager :-)
    Under Android, the issue could be that changes made in the past couple of years to protect the h/w mac-address, same as in iOS which manifested itself as this obfuscation of mac-address last year. As you know this feature has been in Windows for 3+ years but made the most news with iOS14 last year, Google added an option to Android also a few years back, my guess is this might be linked to the issue you have with Android. Some VPN vendors use the virt-mac for all devices {they think who cares as its L3}... some allow you to configure one {not very often} some just don't pass it.... its a jungle.
    HTH
    Danny Jump
  • 7.  RE: Session Notification Enforcement not working for ASA Anyconnect
    Posted Mar 02, 2021 02:09 PM
    OK, thank you Danny - your knowledge definitely helped, cheers!
    And indeed - various OS approaches and limitations are kind of a wild jungle, let's see how far I'll get with this.
    Andris
