My question is : is it possible to configure various session timeout in CPPM ? What I would like is to configure different timeout on my IAP devices (for exemple 1h on an IAP, 2h on another one, ...).
Thanks.
Dimitri
You would create a service that would also filter on NAS IP and create a policy for each NAS device to set a different filter.
Thanks for the help. Do you think it is possible, instead of the NAS ip address (because we doesn't use fixed address), to use the name of the AP ?
Yes, you can use ap name and also ap group.
Thanks, it's fine. One more question, where can I define the AP-Group in an IAP 105 ?
