last person joined: 7 hours ago
Session timeout
  • 1.  Session timeout
    Posted Feb 16, 2015 01:22 AM
    I have a IAP with setting reauth timer to 0
    FreeRadius return session-timer 120s
    If I setup Captive portal with using the RADIUS server, session is stop after 120s
    IAP can force the user to reauthenticate by captive portal.
    That's okay
    However, if i set the employee SSID with "WPA2-Enterprise (802.1x)"
    FreeRadius return session-timer 120s,
    I checked the RADIUS records, there is NO reauthenticate RADIUS/EAP message come in for a long period of time.
    I can only see accouting information.
    Then I try to set reauth timer to 3 min, then IAP will cause user to send reauthen after 3 min.
    It seems that the IAP only follows the reauth timer setting in IAP GUI but not the session-timer from RADIUS.
    May I know if IAP 105 version 6.3 whether support session-timer from Radius for 802.1x authentication ?
  • 2.  RE: Session timeout
    Posted Feb 16, 2015 05:18 AM
    Sir,
    It should work.  What is the exact version of IAP that you are running?
    You can also use the command below to take a look at the radius packets and see if reauthentication is occurring:
    show ap debug auth-trace-buf <mac address of client>
  • 3.  RE: Session timeout
    Posted Feb 16, 2015 11:07 AM
    Thanks for the information.
    Here is the version of the IAP
    Version
    ArubaOS (MODEL: 105), Version 6.3.1.2-4.0.0.4
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-02-20 at 22:26:29 PST (build 42384) by p4build
  • 4.  RE: Session timeout
    Posted Feb 16, 2015 11:38 AM
    About the debug command, I can only retest it again on 23th/Feb after return back to office.
    Actually, I used wireshark to capture the RADIUS traffic (EAP/RAIDUS) in previous test.
    if I set re-authen timer to 0 and use radius to return sesison-timer=120, I cannot find any re-authentication traffic after waiting for long time.
    if I set re-authen timer to 15min and use radius to return sesison-timer=120, I can find re-authentication traffic after 15min only (but not 120s).
    That make me feel the session-timer not working if using WPA2-Enterprise (EAP-PEAP).
    Thank you
  • 5.  RE: Session timeout
    Posted Feb 16, 2015 09:31 PM
    Okay.  Post when you get back into the office.  We cannot really open and make progress on a case unless we get access to your live setup.
  • 6.  RE: Session timeout
    Posted Feb 22, 2015 09:05 PM
    At first, thanks for the reply.
    I tried the debug command.
    I cannot see the re-authentication after session timeout 120s
    I can only see many rad-acct-int-update at the end of debug log
    Please advise if any of my mis-configuration or version not support.
    Version
    00:24:6c:cb:63:e2# show ver
    AP uptime is 20 minutes 37 seconds
    Reboot Time and Cause: unknown
    Radius return AVP
    Code: Access-Challenge response
    AVP: l=6 t=Session-Timeout(27): 120
    AP debug log
    After AP startup, I user a mobile phone connect to the AP
    There is only rad-acct-int-update found at the end of the log
    00:24:6c:cb:63:e2# show ap debug auth-trace-buf
    Auth Trace Buffer
    Jan 1 00:02:38 station-up * 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 - - wpa2 aes
    Jan 1 00:02:38 eap-id-req <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 1 5
    Jan 1 00:02:38 eap-id-resp -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 1 10 david
    Jan 1 00:02:38 rad-req -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 1 202
    Jan 1 00:02:40 rad-resp <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22/MYRADIUS 1 86
    Jan 1 00:02:40 eap-req <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 2 22
    Jan 1 00:02:40 eap-nak -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 2 6
    Jan 1 00:02:40 rad-req -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22/MYRADIUS 2 216
    00:24:6c:36:3e:22/MYRADIUS 2 70
    00:24:6c:36:3e:22 3 6
    Jan 1 00:02:40 eap-resp -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 3 208
    00:24:6c:36:3e:22/MYRADIUS 3 418
    00:24:6c:36:3e:22/MYRADIUS 3 1090
    00:24:6c:36:3e:22 4 1024
    00:24:6c:36:3e:22 4 6
    00:24:6c:36:3e:22/MYRADIUS 4 216
    00:24:6c:36:3e:22/MYRADIUS 4 1086
    00:24:6c:36:3e:22 5 1020
    00:24:6c:36:3e:22 5 6
    00:24:6c:36:3e:22/MYRADIUS 5 216
    00:24:6c:36:3e:22/MYRADIUS 5 594
    00:24:6c:36:3e:22 6 532
    00:24:6c:36:3e:22 6 144
    00:24:6c:36:3e:22/MYRADIUS 6 354
    00:24:6c:36:3e:22/MYRADIUS 6 123
    00:24:6c:36:3e:22 7 65
    00:24:6c:36:3e:22/MYRADIUS 7 216
    00:24:6c:36:3e:22/MYRADIUS 7 101
    00:24:6c:36:3e:22 8 43
    00:24:6c:36:3e:22 8 80
    00:24:6c:36:3e:22/MYRADIUS 8 290
    Jan 1 00:02:41 rad-resp <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22/MYRADIUS 8 117
    Jan 1 00:02:41 eap-req <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 9 59
    Jan 1 00:02:41 eap-resp -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 9 144
    Jan 1 00:02:41 rad-req -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22/MYRADIUS 9 354
    00:24:6c:36:3e:22/MYRADIUS 9 149
    00:24:6c:36:3e:22 10 91
    00:24:6c:36:3e:22 10 80
    00:24:6c:36:3e:22/MYRADIUS 10 290
    00:24:6c:36:3e:22/MYRADIUS 10 101
    00:24:6c:36:3e:22 11 43
    00:24:6c:36:3e:22 11 80
    00:24:6c:36:3e:22/MYRADIUS 11 290
    Jan 1 00:02:41 rad-accept <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22/MYRADIUS 11 167
    Jan 1 00:02:41 eap-success <- 48:5a:3f:06:8b:cb
    Jan 1 00:02:41 wpa2-key1 <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 - 117
    Jan 1 00:02:41 wpa2-key2 -> 48:5a:3f:06:8b:cb
    Jan 1 00:02:41 wpa2-key3 <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 - 151
    Jan 1 00:02:41 wpa2-key4 -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:22 - 95
    Jan 1 00:02:43 rad-acct-start -> 48:5a:3f:06:8b:cb
    Jan 1 00:02:47 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:03:48 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:04:26 rad-acct-stop -> 48:5a:3f:06:8b:cb
    Jan 1 00:04:26 station-up * 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a - - wpa2 aes
    Jan 1 00:04:26 eap-id-req <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a 1 5
    Jan 1 00:04:26 eap-id-resp -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a 1 10 david
    Jan 1 00:04:26 rad-req -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a 16 202
    Jan 1 00:04:26 rad-resp <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a/MYRADIUS 16 86
    Jan 1 00:04:26 eap-req <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a 2 22
    Jan 1 00:04:26 eap-nak -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a 2 6
    00:24:6c:36:3e:2a/MYRADIUS 17 216
    00:24:6c:36:3e:2a/MYRADIUS 17 70
    00:24:6c:36:3e:2a 3 6
    Jan 1 00:04:26 eap-resp -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a 3 208
    00:24:6c:36:3e:2a/MYRADIUS 18 418
    00:24:6c:36:3e:2a/MYRADIUS 18 1090
    00:24:6c:36:3e:2a 4 1024
    00:24:6c:36:3e:2a 4 6
    00:24:6c:36:3e:2a/MYRADIUS 19 216
    00:24:6c:36:3e:2a/MYRADIUS 19 1086
    00:24:6c:36:3e:2a 5 1020
    00:24:6c:36:3e:2a 5 6
    00:24:6c:36:3e:2a/MYRADIUS 20 216
    00:24:6c:36:3e:2a/MYRADIUS 20 594
    00:24:6c:36:3e:2a 6 532
    00:24:6c:36:3e:2a 6 144
    00:24:6c:36:3e:2a/MYRADIUS 21 354
    00:24:6c:36:3e:2a/MYRADIUS 21 123
    00:24:6c:36:3e:2a 7 65
    00:24:6c:36:3e:2a/MYRADIUS 22 216
    00:24:6c:36:3e:2a/MYRADIUS 22 101
    00:24:6c:36:3e:2a 8 43
    00:24:6c:36:3e:2a 8 80
    00:24:6c:36:3e:2a/MYRADIUS 23 290
    00:24:6c:36:3e:2a/MYRADIUS 23 117
    00:24:6c:36:3e:2a 9 59
    00:24:6c:36:3e:2a 9 144
    00:24:6c:36:3e:2a/MYRADIUS 24 354
    00:24:6c:36:3e:2a/MYRADIUS 24 149
    00:24:6c:36:3e:2a 10 91
    00:24:6c:36:3e:2a 10 80
    00:24:6c:36:3e:2a/MYRADIUS 25 290
    00:24:6c:36:3e:2a/MYRADIUS 25 101
    00:24:6c:36:3e:2a 11 43
    00:24:6c:36:3e:2a 11 80
    00:24:6c:36:3e:2a/MYRADIUS 26 290
    Jan 1 00:04:26 rad-accept <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a/MYRADIUS 26 167
    Jan 1 00:04:26 eap-success <- 48:5a:3f:06:8b:cb
    Jan 1 00:04:26 wpa2-key1 <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a - 117
    Jan 1 00:04:26 wpa2-key2 -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a - 135
    Jan 1 00:04:26 wpa2-key3 <- 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a - 151
    Jan 1 00:04:26 wpa2-key4 -> 48:5a:3f:06:8b:cb
    00:24:6c:36:3e:2a - 95
    Jan 1 00:04:26 rad-acct-start -> 48:5a:3f:06:8b:cb
    Jan 1 00:04:48 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:05:49 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:06:51 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:07:52 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:08:52 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:09:53 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:10:53 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:11:54 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:12:54 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:13:54 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:14:54 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:15:54 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:16:54 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:17:55 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:18:55 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:19:55 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:20:55 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Jan 1 00:21:55 rad-acct-int-update -> 48:5a:3f:06:8b:cb
    Configuration
    00:24:6c:cb:63:e2# show run
    version 6.3.1.0-4.0.0
    virtual-controller-country HK
    virtual-controller-key
    d243340901b07769aa5c6e1bbb34226f9852b913f950884c2a
    name Instant-CB:63:E2
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 00:24:6c:cb:63:e2
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin 2e96ab7b029f698668a4fc7c790ca17b
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 1
    rule 10.166.20.238 255.255.255.255 match tcp 80 80 permit
    rule 10.166.20.238 255.255.255.255 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule MYINSTANT
    index 2
    wlan access-rule MYGUEST
    index 3
    wlan ssid-profile MYINSTANT
    enable
    index 0
    type employee
    essid MYINSTANT
    opmode wpa2-aes
    max-authentication-failures 0
    auth-server MYRADIUS
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    radius-reauth-interval 60
    radius-accounting
    radius-interim-accounting-interval 1
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile MYGUEST
    enable
    index 1
    type guest
    essid MYGUEST
    opmode opensystem
    max-authentication-failures 10
    vlan guest
    rf-band all
    captive-portal internal
    dtim-period 1
    radius-reauth-interval 15
    radius-accounting
    blacklist
    auth-survivability cache-time-out 24
    wlan auth-server MYRADIUS
    ip 10.166.19.238
    port 1812
    acctport 1813
    deadtime 1
    key fc502016b2032e1d04699b5cfad9b69627ea139db33df707
    nas-ip 10.166.18.158
    nas-id MYINSTANT
    rfc3576
    cppm-rfc3576-port 5999
    wlan captive-portal
    background-color 13421772
    banner-color 16750848
    banner-text "Welcome to Guest Network"
    terms-of-use "This network is not secure, and use is at your own risk"
    use-policy "Please read terms and conditions before using Guest
    Network"
    authenticated
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
    Confidential Communication - This e-mail (including any attachments) is confidential and may be
    legally privileged. If this e-mail has been sent to you by mistake please inform us by reply
    e-mail and then delete the e-mail, destroy any printed copy and do not disclose or use the
    information in it.
  • 7.  RE: Session timeout
    Posted Feb 22, 2015 11:55 PM
    It should work.  Please open a case with TAC so that we can get your tech-support and look at what is not working in your environment.  We cannot tell what is wrong just from the configuration.
