Wired Intelligent Edge
Configure port controlled-direction via SNMP
  • 1.  Configure port controlled-direction via SNMP
    Posted Aug 16, 2022 08:24 AM
    Hi community!
    I am using 2540 48G Aruba switches on the latest firmware.
    Does anybody know if there is an OID for configuring "aaa port-access controlled-direction" port setting via SNMP.
    Thx in advance!
  • 2.  RE: Configure port controlled-direction via SNMP
    Posted Aug 16, 2022 02:24 PM
    Please try dot1xAuthAdminControlledDirections  from the IEEE 802.1X MIB.
    https://www.ieee802.org/1/files/public/MIBs/802-1x-2001-mib.txt
    Numerical value is 1.0.8802.1.1.1.1.2.1.1.3
    dot1xAuthAdminControlledDirections OBJECT-TYPE
    SYNTAX PaeControlledDirections
    MAX-ACCESS read-write
    STATUS current
    DESCRIPTION
    "The current value of the administrative controlled
    directions parameter for the Port."
    REFERENCE
    "9.4.1, Admin Control Mode"
    ::= { dot1xAuthConfigEntry 3 }
    From what I see on the switch value 0 means controlled-direction both and 1 -in.
  • 3.  RE: Configure port controlled-direction via SNMP
    Posted Aug 17, 2022 01:44 AM
    That's it! Thank you very much!
