Default Web Page?
You can only do that if you are using Captive Portal to authenticate users somehow.
The easiest way to do that is to Run the WLAN/LAN Wizard. It will ask you if you want to do PSK, etc and then ask you if you want to do Captive Portal. After that you can configure the "Welcome Page" in the Captive Portal Authentication profile.
