Set endpoint attribute during onboard
  • 1.  Set endpoint attribute during onboard
    Posted Dec 17, 2017 05:18 AM
    Hi community,
    Is it possible to set an endpoint attribute during the onboard process of that endpoint (for example, set endpoint's username equals to the user that is onboarding)? I want to use that attribute for enforcement decision later when the endpoint does 802.1X authentication to the wireless network.
    Please give me some advice.
    Thank you,
  • 2.  RE: Set endpoint attribute during onboard
    Posted Dec 17, 2017 06:12 PM
    Yes, you can. Use a ClearPass Enttity Update enforcement profile.
  • 3.  RE: Set endpoint attribute during onboard
    Posted Dec 17, 2017 11:41 PM
    Hi Tim,
    It didn't work though I can see the status was ACCEPT. Below is my configuration and the log messages:
    Could you please verify if this is a valid configuration? I guess the profile was not applied due to no End-Host Identifier available during onboard.
    Thank you,
