set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
  • 1.  set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    MVP
    Posted Sep 25, 2022 12:58 AM
    As I see, WLCs clustering is the preferable Aruba design at this moment.
    How can I set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary ? (I need to swap primary and secondary in my design)
    #show lc-cluster group-membership
    Cluster Enabled, Profile Name = "p-cluster"
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    Heartbeat Threshold = 2000 msec
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 20%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 50
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    self 10.15.244.70 128 N/A CONNECTED (Member)
    peer 10.15.244.71 128 L2-Connected CONNECTED (Leader)
  • 2.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    Posted Sep 25, 2022 04:31 PM
    What is the point of switching the primary for devices?  That would determine how to answer your question.
  • 3.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    MVP
    Posted Sep 25, 2022 09:18 PM
    maybe I not fully understand yet cluster functions,
    my point is that when I login to a WLC2 I see all access points connected to it and no access points connected to WLC1, I would like to have all access points on WLC1
  • 4.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    Posted Sep 25, 2022 10:15 PM
    Then change the priority for wlc1 as higher than wlc2 then all access points will terminate in wlc1
    Best Regards,
    Rashed Basuleman
  • 5.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    MVP
    Posted Sep 25, 2022 10:19 PM
    yes, so my query was how can I set priority on WLCs for that.
  • 6.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    Posted Sep 25, 2022 10:32 PM
    (host)(config) #vrrp 22
    vlan 22
    ip address 10.200.22.254
    priority 110
    preempt
    authentication password
    description Preferred-Master
    tracking master-up-time 30 add 20
    no shutdown
    The following configuration is the corresponding VRRP configuration for the peer controller.
    vlan 22
    priority 100
    preempt
    description Backup-Master
    no shutdown
    Best Regards,
    Rashed Basuleman
  • 7.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    MVP
    Posted Sep 25, 2022 10:40 PM
    these provided commands relate only to VRRP,
    but even before configuration of VRRP , when I built an L2 cluster from WLCs , they already shown me:
    It is only via VRRP priority possible to assign such WLCs priority ?!
  • 8.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    Posted Sep 25, 2022 10:46 PM
    https://youtu.be/pUdiNAn158Y
    Best Regards,
    Rashed Basuleman
  • 9.  RE: set priority per WLC to make WLC1 as primary in the cluster and WLC2 as secondary
    Posted Sep 26, 2022 12:37 AM
    That is incorrect.  That video is for master redundancy.  Once you create a cluster with an MM in the picture, the VRRP is not used to influence what controller has "priority".  The parameters in the cluster profile do that.
