Set Specific Channel on AP-105
  • 1.  Set Specific Channel on AP-105
    MVP
    Posted Oct 17, 2013 10:40 AM
    Is there a way to set the 2.4GHz radio on an AP-105 to a specific channel (ie 1, 6, 11)? I looked in the config but have not come up with anything.
  • 2.  RE: Set Specific Channel on AP-105
    Posted Oct 17, 2013 11:24 AM
    You would have to create a new ap-group.  You would also have to create a new regulatory domain profile that only has that single channel and assign it to that ap-group.  Reprovision the access point to that new ap-group.
    Alternatively, you can create an AP-Specific configuration and create a new Regulatory domain profile for that AP-Specific Configuration.
  • 3.  RE: Set Specific Channel on AP-105
    Posted Oct 17, 2013 11:27 AM
    Sure,
    Here is one method, for the specific AP in question:
    1.  Turn off ARM channel changing (set to maintain)
    2.  Set Default channel in dot11g Radio Profile to the desired 1,6,11
    99.9% of the time I would just let Aruba ARM do-its-thing and select the best channel... remember the RF environment is constantly changing, the AP needs to 'keep up'.
    JF
  • 4.  RE: Set Specific Channel on AP-105
    Posted Oct 30, 2013 11:29 AM
    thanks,
    you means diable ARM assignment? and in the regulatory domain profile, choose the channel value which I expert?
