set time ranges on Aruba instant 105
  • 1.  set time ranges on Aruba instant 105
    Posted Sep 16, 2012 05:47 AM
    Hey
    Is it possible to set time ranges on the instant ap's  like on the mobility controller. Or is there any other possibility to set a period of time where clients can access the internet and other times where there are no access?
    Best regards
    Peder
  • 2.  RE: set time ranges on Aruba instant 105
    Posted Sep 16, 2012 06:01 AM
    It is not possible, no.
  • 3.  RE: set time ranges on Aruba instant 105
    Posted Sep 27, 2013 03:00 PM
    It is a feature request which has been posted on the ideas portal.
    If you have access to it, go ahead and promote the idea pederdalgaard
  • 4.  RE: set time ranges on Aruba instant 105
    Posted Oct 05, 2013 09:17 PM
    You could also achieve this by leveraging a MAS switch for your PoE needs. Can turn down the ports when desired :)
