Set up Aruba IAP-305 APs on CIsco 3750G Switches
  • 1.  Set up Aruba IAP-305 APs on CIsco 3750G Switches
    Posted Sep 01, 2020 06:13 PM
    I am trying out runnig a group of IAP-305 APs on my network backed by Cisco 3750G switches.  I can get them to connect correctly to all my Wireless VLANS on site, but they are not pulling down an AP address that I can see or reporting to Aruba Central.  Ports are set up as follows:
    switchport trunk encapsulation dot1q
    switchport trunk native vlan 50
    switchport trunk allowed vlan 7-9,15
    switchport mode trunk
    switchport voice vlan 11
    Is there something I'm missing?
  • 2.  RE: Set up Aruba IAP-305 APs on CIsco 3750G Switches
    Posted Sep 01, 2020 06:52 PM
    do you men they are not getting IP addresses? if that is the case, you need to have a DHCP scope on your DHCP server
  • 3.  RE: Set up Aruba IAP-305 APs on CIsco 3750G Switches
    Posted Sep 02, 2020 12:15 AM
    You'll want to add vlan 50 to your allowed list on the trunk.  Should grab a dhcp address at that point.
  • 4.  RE: Set up Aruba IAP-305 APs on CIsco 3750G Switches
    Posted Sep 02, 2020 07:35 AM
    I thought you only put the wireless VLANS in the trunk list.  50 is my management VLAN.
    We did set up a DHCP scope.  I have had a couple work for a out 5-10 minutes sending to Aruba and grabbing IPs but then they are not seen anymore by Aruba Central even though they are still broadcasting.
