Cloud Managed Networks
Set up Comcast EDI on Aruba 6200F
  • 1.  Set up Comcast EDI on Aruba 6200F
    Posted Feb 07, 2024 06:57 PM
    I've just recently become responsible for maintaining the company network and am trying to set up Comcast EDI on a 2500 Mobility Access Switch and then migrate to a HPE Aruba CX 6200F. The gateway router is a Ubiquiti UDMPRO. I am reading the fundamentals guide and reviewing comcast information, trying to understand how I can set up a NAT on both switches and I am at a loss for how to proceed. I have verified the link is active by plugging a laptop to the comcast port and configuring the laptop interface with the WAN Block IP address, netmask and gateway. TIA.
    The Comcast information is below.
    Customer Layer 3 IP Information
    (WAN Block)
    Customer Usable IP Information
    (LAN Block)
    Link IP Address:
    50.xx.xx.0/30<w:sdtpr></w:sdtpr>
    <w:sdt docpart="70BFA02F335B4E899E299AA6172DBA8E" text="t" id="-757604394"></w:sdt>
    Usable IP Block:
    50.xx.xx.44/29<w:sdtpr></w:sdtpr>
    <w:sdt docpart="A03ED049770F404988E84E5B03AA9D76" text="t" id="1084028453"></w:sdt>
    Gateway:
    50.xx.xx.1<w:sdtpr></w:sdtpr>
    <w:sdt docpart="F895A61937D843438FC8469C5CD9420D" text="t" id="630069757"></w:sdt>
    Usable IP Ranges:
    50.xx.xx.45-50.xx.xx.50<w:sdtpr></w:sdtpr>
    <w:sdt docpart="86AEF6AC28A5471D8F2172EDF93BC060" text="t" id="-835074568"></w:sdt>
    Layer 3 IP:
    50.xx.xx.2<w:sdtpr></w:sdtpr>
    <w:sdt docpart="92BBF22893F049D898B3E4326F9E172F" text="t" id="403733876"></w:sdt>
    Usable Subnet Mask:
    255.255.255.248<w:sdtpr></w:sdtpr>
    <w:sdt docpart="C80A62B682B04AA68FCD1834B16C65B0" text="t" id="-450474298"></w:sdt>
    Layer 3 Subnet Mask:
    255.255.255.252<w:sdtpr></w:sdtpr>
    <w:sdt docpart="F45EB6635A164A15968CD887CD27F288" text="t" id="1684866362"></w:sdt>
    Usable IPv6 Block:
    N/A
    <w:sdt docpart="55E6E06E5FC14AB283EB09397C28C316" text="t" id="-161858974"></w:sdt>
    The configuration for the mobility switch
    # ArubaOS Version 7.4
    version 7.4
    enable secret "******"
    enable bypass
    hostname "main"
    clock timezone PST -8
    controller config 1
    ip access-list eth validuserethacl
      permit any
    netservice svc-dhcp udp 67 68
    netservice svc-dns udp 53
    netservice svc-ftp tcp 21
    netservice svc-h323-tcp tcp 1720
    netservice svc-h323-udp udp 1718 1719
    netservice svc-http tcp 80
    netservice svc-https tcp 443
    netservice svc-icmp 1
    netservice svc-kerberos udp 88
    netservice svc-natt udp 4500
    netservice svc-ntp udp 123
    netservice svc-sip-tcp tcp 5060
    netservice svc-sip-udp udp 5060
    netservice svc-sips tcp 5061
    netservice svc-smtp tcp 25
    netservice svc-ssh tcp 22
    netservice svc-telnet tcp 23
    netservice svc-tftp udp 69
    netservice svc-vocera udp 5002
    ip access-list stateless allowall-stateless
      any any any  permit
    ip access-list stateless cplogout-stateless
      user   alias controller sys-svc-https  dst-nat 8081
    ip access-list stateless dhcp-acl-stateless
      any any svc-dhcp  permit
    ip access-list stateless dns-acl-stateless
      any any svc-dns  permit
    ip access-list stateless http-acl-stateless
      any any svc-http  permit
    ip access-list stateless https-acl-stateless
      any any svc-https  permit
    ip access-list stateless icmp-acl-stateless
      any any svc-icmp  permit
    ip access-list stateless logon-control-stateless
      any any svc-natt  permit
    ip access-list session validuser
      network 169.254.0.0 255.255.0.0 any any  deny
      any any any  permit
    user-role authenticated
    user-role denyall
    user-role denydhcp
    user-role guest
    user-role logon
    user-role preauth
    crypto ipsec transform-set default-boc-bm-transform esp-aes256 esp-sha-hmac
    crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
    mgmt-user ntwrkadmin root XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    no firewall prohibit-ip-spoofing
    firewall disable-stateful-sip-processing
    firewall disable-stateful-h323-processing
    firewall disable-stateful-sccp-processing
    ip domain lookup
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa server-group "default"
     auth-server Internal
     set role condition role value-of
    aaa profile "default"
    aaa authentication captive-portal "default"
    aaa authentication vpn "default"
    aaa authentication mgmt
    aaa authentication wired
    web-server
    papi-security
    aaa password-policy mgmt
    traceoptions
    probe-profile "default"
       protocol icmp
    qos-profile "default"
    policer-profile "default"
    ip-profile
       default-gateway 172.16.1.1
       route 172.16.18.0 255.255.255.0 172.16.4.10 0
       route 172.16.21.0 255.255.255.0 172.16.4.10 0
       controller-ip vlan 1
    lcd-menu
    interface-profile ospf-profile "default"
       area 0.0.0.0
    interface-profile pim-profile "default"
    interface-profile igmp-profile "default"
    stack-profile
    ipv6-profile
    activate-service-firmware
    aruba-central
    rogue-ap-containment
    interface-profile switching-profile "default"
       access-vlan 8
    interface-profile switching-profile "trunk"
       switchport-mode trunk
       trunk allowed vlan 1-1999
    interface-profile switching-profile "trunk-with-wan"
    interface-profile switching-profile "wan-primary"
       access-vlan 4002
    interface-profile switching-profile "wan-comcast"
       access-vlan 4007
    interface-profile switching-profile "wan-old-primary"
       access-vlan 4004
    interface-profile switching-profile "wan-secondary"
       access-vlan 4001
    interface-profile switching-profile "wan-mobile"
       access-vlan 4006
    interface-profile poe-profile "default"
       enable
    interface-profile poe-profile "poe-factory-initial"
       enable
    interface-profile enet-link-profile "default"
    interface-profile lldp-profile "default"
    interface-profile lldp-profile "lldp-factory-initial"
       lldp transmit
       lldp receive
    interface-profile mstp-profile "default"
    interface-profile pvst-port-profile "default"
    vlan-profile dhcp-snooping-profile "default"
    vlan-profile mld-snooping-profile "default"
    vlan-profile igmp-snooping-profile "default"
    vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
    spanning-tree
       mode mstp
    gvrp
    mstp
    lacp
    vlan "1"
       description "Management"
    vlan "4"
       description "DC"
    vlan "5"
       description "Clients"
    vlan "8"
       description "OOO"
    vlan "9"
       description "IOT"
    vlan "4001"
       description "WAN Secondary"
    vlan "4002"
       description "WAN Primary"
    vlan "4003"
       description "WAN via gw"
    vlan "4004"
       description "WAN old Primary"
    vlan "4006"
       description "WAN Mobile"
    vlan "4007"
       description "WAN Comcast"
    interface gigabitethernet "0/0/24"
    interface gigabitethernet "0/0/25"
    interface gigabitethernet "0/0/26"
    interface gigabitethernet "0/0/27"
    interface gigabitethernet "0/0/28"
    interface gigabitethernet "0/0/29"
    interface gigabitethernet "0/0/30"
    interface gigabitethernet "0/0/31"
    interface gigabitethernet "0/0/32"
    interface gigabitethernet "0/0/33"
    interface gigabitethernet "0/0/34"
    interface gigabitethernet "0/0/35"
    interface gigabitethernet "0/0/36"
    interface gigabitethernet "0/0/37"
    interface gigabitethernet "0/0/38"
    interface gigabitethernet "0/0/39"
    interface gigabitethernet "0/0/40"
    interface gigabitethernet "0/0/41"
    interface gigabitethernet "0/0/42"
    interface gigabitethernet "0/0/43"
    interface gigabitethernet "0/0/44"
    interface gigabitethernet "0/0/45"
    interface gigabitethernet "0/0/46"
    interface gigabitethernet "0/0/47"
    interface gigabitethernet "0/1/0"
    interface gigabitethernet "0/1/1"
    interface gigabitethernet "0/1/2"
    interface gigabitethernet "0/1/3"
    interface vlan "1"
       ip address 172.16.1.2 255.255.255.0
    interface mgmt
       ip address 10.0.0.1 255.255.255.0
    device-group ap
    interface-group gigabitethernet "default"
       apply-to ALL
    snmp-server community Zer0t0uchpr0visi0ning view ALL
    snmp-server view ALL oid-tree iso included
    snmp-server group ALLPRIV v1 read ALL notify ALL
    snmp-server group ALLPRIV v2c read ALL notify ALL
    snmp-server group ALLPRIV v3 noauth read ALL notify ALL
    snmp-server group AUTHPRIV v3 priv read ALL notify ALL
    snmp-server group AUTHNOPRIV v3 auth read ALL notify ALL
    snmp-server group Zer0t0uchpr0visi0ning v1 read ALL
    snmp-server group Zer0t0uchpr0visi0ning v2c read ALL
    snmp-server enable trap
    process monitor log
    end
    Configuration for the 6200F
    !Version ArubaOS-CX ML.10.10
    !export-password: default
    hostname sw1
    banner motd !
    sw1!
    user ntwrkadmin group administrators password ciphertext XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    ssh server vrf default
    ssh server vrf mgmt
    vsf member 1
        type jl727a
    system internal-vlan-range 3000-3051
    vlan 1
    vlan 4
        name Datacenter Tunnel
    vlan 5
        name Clients
    vlan 8
        name OOO
    vlan 9
        name IOT
    vlan 4001
        name WAN Secondary
    vlan 4002
        name WAN Primary
    vlan 4003
        name WAN via gw
    vlan 4004
        name WAN Old Primary
    vlan 4006
        name WAN Mobile
    vlan 4007
        name WAN Comcast
    spanning-tree
    interface mgmt
        no shutdown
        ip dhcp
    qos dscp-map 0 local-priority 0
    qos dscp-map 1 local-priority 0
    qos dscp-map 2 local-priority 0
    qos dscp-map 3 local-priority 0
    qos dscp-map 4 local-priority 0
    qos dscp-map 5 local-priority 0
    qos dscp-map 6 local-priority 0
    qos dscp-map 7 local-priority 0
    qos dscp-map 8 local-priority 1
    qos dscp-map 9 local-priority 1
    qos dscp-map 10 local-priority 1
    qos dscp-map 11 local-priority 1
    qos dscp-map 12 local-priority 1
    qos dscp-map 13 local-priority 1
    qos dscp-map 14 local-priority 1
    qos dscp-map 15 local-priority 1
    interface 1/1/1
        no shutdown
        no routing
        vlan access 8
    interface 1/1/2
        no shutdown
        no routing
        vlan access 8
    interface 1/1/3
        no shutdown
        no routing
        vlan access 8
    interface 1/1/4
        no shutdown
        no routing
        vlan access 8
    interface 1/1/5
        no shutdown
        no routing
        vlan access 8
    interface 1/1/6
        no shutdown
        no routing
        vlan access 8
    interface 1/1/7
        no shutdown
        no routing
        vlan access 8
    interface 1/1/8
        no shutdown
        no routing
        vlan access 8
    interface 1/1/9
        no shutdown
        no routing
        vlan access 8
    interface 1/1/10
        no shutdown
        no routing
        vlan access 8
    interface 1/1/11
        no shutdown
        no routing
        vlan access 8
    interface 1/1/12
        no shutdown
        no routing
        vlan access 8
    interface 1/1/13
        no shutdown
        no routing
        vlan access 8
    interface 1/1/14
        no shutdown
        no routing
        vlan access 8
    interface 1/1/15
        no shutdown
        no routing
        vlan access 8
    interface 1/1/16
        no shutdown
        no routing
        vlan access 8
    interface 1/1/17
        no shutdown
        no routing
        vlan access 8
    interface 1/1/18
        no shutdown
        no routing
        vlan access 8
    interface 1/1/19
        no shutdown
        no routing
        vlan access 8
    interface 1/1/20
        no shutdown
        no routing
        vlan access 8
    interface 1/1/21
        no shutdown
        no routing
        vlan access 8
    interface 1/1/22
        no shutdown
        no routing
        vlan access 8
    interface 1/1/23
        no shutdown
        no routing
        vlan access 8
    interface 1/1/24
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed 1,4-5,8-9
    interface 1/1/25
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/26
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/27
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/28
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/29
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/30
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/31
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/32
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/33
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/34
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/35
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/36
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/37
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/38
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/39
        description WAN Comcast Port1
        no shutdown
        routing
        ip address 50.xx.xx.2/30
    interface 1/1/40
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed 1,4-5,8-9,4001-4004,4006-4007
    interface 1/1/41
        description WAN Mobile
        no shutdown
        no routing
        vlan access 4006
    interface 1/1/42
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/43
        description WAN old Primary port5
        no shutdown
        no routing
        vlan access 4004
    interface 1/1/44
        description Port10 UDMPRO
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/45
        description WAN Primary Port6
        no shutdown
        no routing
        vlan access 4002
    interface 1/1/46
        description Port9 UDMPRO
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/47
        description Secondary
        no shutdown
        no routing
        vlan access 4001
    interface 1/1/48
        no shutdown
        no routing
        vlan access 1
    interface 1/1/49
        description sw2
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/50
        description ssw
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/51
        description sw
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/52
        description Port11 UDMRO
        no shutdown
        no routing
        vlan trunk native 1
    interface vlan 1
        description Management
    interface vlan 4
        description DC
    interface vlan 5
        description Clients
    interface vlan 8
        description OOO
    interface vlan 9
        description IOT
    interface vlan 4001
        description WAN Secondary
    interface vlan 4002
    interface vlan 4003
        description WAN via gw
    interface vlan 4004
    interface vlan 4006
    interface vlan 4007
        ip address 50.xx.xx.44/29
    ip route 0.0.0.0/0 172.16.1.1
    ip route 50.xx.xx.0/30 50.xx.xx.1
    ip route 172.16.17.0/24 172.16.4.10
    ip route 172.16.21.0/24 172.16.4.10
    ip dns domain-name corp.company.com
    ip dns domain-list company.com
    ip dns server-address 172.16.8.1
    ip dns server-address 172.16.4.10
    https-server vrf default
    https-server vrf mgmt
  • 2.  RE: Set up Comcast EDI on Aruba 6200F
    Posted Feb 08, 2024 10:27 AM
    Does it work already with the S2500 switch, and do you need to move that to the 6200? Or are both switches new?
    The 6200 will not to NAT, and normally you do NAT on the gateway/router instead of on the switch.
    You probably should connect that Comcast device to your UDMPRO in some way. Not sure if it supports multiple uplinks, and if you want to replace the current internet connection or have them in parallel. In either case you probably should not route this on your switch but let the switch do L2 connectivity and a router/gateway handle the L3 routing/NAT. Having multiple internet connections can be quite challenging from a routing/failover perspective, but your switches will probably not play a role in here (in this type of deployment).
  • 3.  RE: Set up Comcast EDI on Aruba 6200F
    Posted Feb 08, 2024 03:57 PM
    Thanks, Herman.
    I have not set it up on the S2500. The switch is EOL and starting to
    lose connectivity on ports 1-24. The 6200 is new.
  • 4.  RE: Set up Comcast EDI on Aruba 6200F
    Posted Feb 09, 2024 07:07 AM
    When I look quickly, I don't see NAT configured on the S2500.. there is too much configuration to do a full comparison between the two configs, but high-level many things like VLAN and VLAN interfaces look similar. I would move out routing from the switch as much as possible in a network with just a few switches, let the gateway/router do the routing between VLANs, as well NAT towards the internet.
