set up SSH public-key authentication to connect to a ClearPass?
  • 1.  set up SSH public-key authentication to connect to a ClearPass?
    Posted Jan 28, 2020 08:31 PM
    How to set up SSH public-key authentication to connect to a ClearPass (6.7.10 on C1000 platform)?
    According to below post, I should get a "network" option under the configuration but I can't see it.
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-do-I-set-up-SSH-public-key-authentication-to-connect-to-a/ta-p/274857
    Can anyone please help me how to set up SSH public-key authentication to connect to a ClearPass?
    We use "rancid" to fetch config and after implementation of 802.1X on cisco switches, the rancid fails for authentication. It uses ssh keys.
    Thank you.
  • 2.  RE: set up SSH public-key authentication to connect to a ClearPass?
    Posted Jan 28, 2020 08:38 PM
    Just checked on version 6.7.7.109065 and can see SSH Public Keys: under Network. Just to make sure, you are looking at the following path:
    Administration » Server Manager » Server Configuration - Server Name
    Can you share a screenshot of what you are seeing?
  • 3.  RE: set up SSH public-key authentication to connect to a ClearPass?
    Posted Jan 28, 2020 08:47 PM
    Hi Jibran,
    Attached is a screenshot.
    Thanks for your time.
