hi,I use Aruba Mobility Controller 3600, with AP-135I am trying to create a static 11a channel 48 in legacy. My configuration commands(not copying ssid profile)(Aruba3600) (config) #rf dot11a-radio-profile mydot11aradioprofile(Aruba3600) (802.11a radio profile "mydot11aradioprofile") #no high-throughput-enable(Aruba3600) (802.11a radio profile "mydot11aradioprofile") #channel 48(Aruba3600) (config) #wlan virtual-ap myvirtualap(Aruba3600) (Virtual AP profile "myvirtualap") #allowed-band a(Aruba3600) (Virtual AP profile "myvirtualap") #ssid-profile myssidprofile(Aruba3600) (Virtual AP profile "myvirtualap") #vlan 20(Aruba3600) (config) #ap-name 6c:f3:7f:ce:60:a2(Aruba3600) (AP name "6c:f3:7f:ce:60:a2") #virtual-ap myvirtualap(Aruba3600) (AP name "6c:f3:7f:ce:60:a2") #dot11a-radio-profile mydot11aradioprofileMy ssid shows channel 149. It is not setting to desired channel. The default regulatory profile default shows 48 as valid channel.(Aruba3600) (config) # show ap regulatory-domain-profile defaultRegulatory Domain profile "default"-----------------------------------Parameter Value--------- -----Country Code USValid 802.11g channel 1Valid 802.11g channel 6Valid 802.11g channel 11Valid 802.11a channel 36Valid 802.11a channel 40Valid 802.11a channel 44Valid 802.11a channel 48Valid 802.11a channel 149Valid 802.11a channel .........Also, the dot11a radio profile, the channel is set.(Aruba3600) (config) #show rf dot11a-radio-profile mydot11aradioprofile802.11a radio profile "mydot11aradioprofile"--------------------------------------------Parameter Value--------- -----Radio enable EnabledMode ap-modeHigh throughput enable (radio) DisabledChannel 48Beacon Period 100 msecNon-Wi-Fi Interference Immunity 2Please tell how I can set the channel 48.Thanks in advance.--uv.
Hi Friend,
Is your ARM enabled or disabled ??
Check and disable.
Please feel free for any further help on this
Here are steps to disable ARM
Notedown the ARM-profile
1. show rf dot11a-radio-profile mydot11aradioprofile
2. arm-profile <profile name>
3. assignment disable
repeat the same for g radio if you need.
Hope this will help you.
thanks a lot. it worked.
