Is it at all possible to set different roles on incoming gre tunnels?
We've got several devices tunneling guest-traffic back to the central controller.
One of the tunnels carries guest-traffic where another carries byod-traffic.
I've set the aaa wired profile to a guest-logon so the guests get redirected to a captive portal but the byod users should be given a different role. Ideally I would be able to simply set different roles to different ports or tunnels but this does not seem the case?
It there any 'clean' way to solve this or will I have to go figure out whether user derivation rules and dhcp option 77 (the only option I can think that doesn't require a lot of 'maintenance') is a possibility?
edit: mm dhcp option 77 doesn't seem to be a sollution either. :smileymad:
