Setting bandwidth limit on guest users
  • 1.  Setting bandwidth limit on guest users
    Posted Aug 31, 2016 08:43 AM
    I want to setup bandwidth limits on the guest WLAN per user, but all I can find are bandwidth limits on applications/web pages and create bandwidth white lists... I tried following this guide, but none of the options exist..
    http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/Firewall_Roles/User_Roles.htm
    I am trying to do so on an Aruba 7005 controller running 6.4.3. Does anyone know where I can set this.
    Kind regards,
    Tom
  • 2.  RE: Setting bandwidth limit on guest users
    Posted Aug 31, 2016 08:47 AM
    Do you have PEF licenses installed?
  • 3.  RE: Setting bandwidth limit on guest users
    Posted Aug 31, 2016 08:49 AM
    Not yet. Do you need PEF licenses for that? I will get that sorted then..
    I presume I'll need PEF licenses to limit the connection time too or is that something else?
  • 4.  RE: Setting bandwidth limit on guest users
    Posted Aug 31, 2016 08:59 AM
    You need PEF for limiting bandwidth.  You can send a radius COA from a radius server to disconnect a user without a bandwidth limit.
