We just had a Penetration test ran on our domain. Once of the items that came up was my Flexfabric 5700 switches support SSH Version 1. I can't figure out how to set the compatability setting for SSH. I see the command under the SSH, but the only excepted option is "enable". I want to disable. Anyone know how to do that in the FlexFabric OS?
Comment from Pen Tester
The remote SSH daemon supports connections made using the version 1.33 and/or 1.5 of the SSH protocol. These protocols are not completely cryptographically safe so they should not be used.The remote service offers an insecure cryptographic protocol.
There Solution
Disable compatibility with version 1 of the protocol.
#ssh
