setting the NAS IP globally on the master controller
  • 1.  setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 10:30 AM
    hello Airheads,
    If you have for example a master controller and two locals and you
    set up a NAS IP on the master controller under "configuration\security\authentication\advanced"
    do all RADIUS requests from clients that associate to an AP on a local controller get proxied from the master controller NAS ip?
  • 2.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 10:33 AM
    What you need to do is configure the following so the request comes from every individual controller:
    ip radius nas-ip <CONTROLLER MGMT IP>
    ip radius source-interface vlan <CONTROLLER MGMT VLAN ID>
  • 3.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 10:36 AM
    hi Victor,
    i would like the RADIUS request to come only from the master.
    cheers
    Pete
  • 4.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 10:41 AM
    That's not possible. Instead you'd want to key off of a different attribute on your radius server like NAS-ID. You'll still need to add in the controllers as radius clients.
    Sent from Nine
  • 5.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 10:48 AM
    thanks for the replies chaps.
    i am trying to take advantage of RADIUS load balancing to multiple Publishers.
    I have AP's terminating on diferent local controllers and guests who sign up to a Publisher
    through one AP and may roam to another AP which is on a different local controller.
    Subsequebnt to guest account creation I want use MAC AUTH to the original Publisher the guest signed up with so hence i wanted to
    try and centralize the RADIUS activity.
  • 6.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 10:51 AM
    The problem with doing that is you would be completely dependent on the master controller for auth rendering all other redundancy irrelevant.
    Sent from Nine
  • 7.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 11:02 AM
    agreed single point of failure bu
    could you have a master\backup master pair
  • 8.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 11:44 AM
    Just need to use the VIP of VRRP then
  • 9.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 11:47 AM
    Hi Victor,
    could you explain a bit further, i have lost the thread a bit.
    pete
  • 10.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 12:00 PM
    In order to have a Master/Standby Master you need a VRRP setup which requires a Virtual IP that both controllers shared in an Active/Standby setup.
    You could use this IP address to send all your RADIUS request from both locals as well as master running this command:
    IP radius nas-ip
    If you have only Master then you just put the Master Management IP address instead of the VIP VRRP address.
  • 11.  RE: setting the NAS IP globally on the master controller
    Posted Dec 17, 2015 12:03 PM
    thanks Victor i think we have a solution.
    cheers
    Pete
  • 12.  RE: setting the NAS IP globally on the master controller
    Posted Dec 18, 2015 01:58 AM
    hi Victor,
    one last point.
    using this configuration would the master keep a record of all authentications?
    so i can use RADIUS load balancing.
    cheers
    Pete
  • 13.  RE: setting the NAS IP globally on the master controller
    Posted Dec 18, 2015 06:44 AM
    Pete_Elms,
    In a word, no.
    The way you configure server load balancing is detailed here:  http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/AAA_Servers/Load_Balancing.htm
  • 14.  RE: setting the NAS IP globally on the master controller
    Not proxied. It only sets that attribute. The source IP address is still the controller it came from.
