Wired
Setting up 2 VLAN on a 1930 switch behind the same router
This thread has been viewed 23 times
  • 1.  Setting up 2 VLAN on a 1930 switch behind the same router
    Posted Mar 15, 2022 10:35 AM
    Hello.
    My customer bought a 1930 switch to put behind a Draytek router. What he intends to have:
        - Ports 1-29: his default LAN, using 192.168.1.x . In port 1 it is connected to ethernet cable that is in the port 1 of the Draytek
        - Ports 30-48: create a VLAN using range 10.10.10.x
    I have set up the ports 30-48 to be tagged to VLAN 2. On other hand, I have enabled VID 2 in the Draytek router.
    I have tried:
        - Having only one cable connected between the switch and the router, the computer that are connected, eg, in port 30 is unable to get the IP and navigate
        - I tried to connect a second cable in Port 2 of the Draytek and in Port 30 of the switch and I assigned VID 2 to Port 2 of the router. Doing this, all the network stopped working.includin the computers that are connected until the port 29 of the switch.
    I don't know how can I solve this.
    Thanks for your time.
    Charles Chapman
  • 2.  RE: Setting up 2 VLAN on a 1930 switch behind the same router
    Posted Aug 09, 2022 07:39 AM
    Hello! Did you manage to solve this issue? I'm about to deploy a draytek 2915 with aruba 1830 switch and I''ve started worrying after I saw your message..!!
  • 3.  RE: Setting up 2 VLAN on a 1930 switch behind the same router
    Posted Aug 09, 2022 08:20 AM
    What are you worried about? 1830 and 1930 are completely different switches.
    If you understand VLAN, tagged/untagged and spanning tree, you should be good. That is where the original message seems to have a problem.
  • 4.  RE: Setting up 2 VLAN on a 1930 switch behind the same router
    Posted Aug 11, 2022 03:47 AM
    Yes I understand and I ve set up millions of vlans, with many vendors I was just worried if it might be  any vlan incompatibility between these vendors (draytek Aruba) , some years ago I had problem with vlan tagging and untagging with zyxel router and other vendors. I don't think that it will have issues
  • 5.  RE: Setting up 2 VLAN on a 1930 switch behind the same router
    Posted Aug 10, 2022 11:37 PM
    hi..
    don't put another cable for the vlan uplink..
    did you setup the dhcp server in your draytek router? for the subnet of your vlan?
    who is responsible for routing?
    thankyou
  • 6.  RE: Setting up 2 VLAN on a 1930 switch behind the same router
    Posted Aug 10, 2022 11:42 PM
    tag port 30-48 (vlan2) to your uplink port1
