Network Management
setting up an Airwave user using cli
  • 1.  setting up an Airwave user using cli
    Posted Jun 07, 2015 06:00 PM
    LDAP on my Airwave stopped working and I can't remember my admin password. Is there a way I can setup an Airwave user in CLI and give it admin rights?
  • 2.  RE: setting up an Airwave user using cli
    Posted Jun 09, 2015 11:23 AM
    From (http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Airwave-Password-Recovery/td-p/34149)
    If you've lost the password you use to log in as admin to AMP's web interface, you can update it from the command line with this command which stores a hashed version of 'admin' as the password in our database:
    From the CLI:
    # dbc "update users set password='2cf94b0aea63ebf7bf41c90fe500603e' where username ='admin';"
    If you use a name other than admin, you can change your user's password by modifying the where clause above. For example, to change joemontana's password to admin, this would work:
    # dbc "update users set password='2cf94b0aea63ebf7bf41c90fe500603e' where username ='joemontana';"
