Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
  • 1.  Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 11:00 AM
    Hello all! This is my first post here, so hello everyone! Also, I apologize if I have this in the wrong place, but I thought this looked like the most appropriate place for my question.
    I have an interesting problem, and I'm not sure where the exact problem lies or even how to ask the right question to get a solution. So, I think I'm just going to explain my situation and what I'm trying to accomplish, so I apologize again for this being so long!
    I have an existing Aruba network at my High School with around 20 AP-105s. My controller lives in the Middle School where my main server closet is, and it is an Aruba 3600 controller. The two locations are tied together with dedicated fiber, and it's working splendid.
    I have purchased around 50 more APs to set up in our Middle School/Elementary school building (the same building where the controller lives). My plan is to set them up exactly like I have at the HS using the same controller.
    After getting my new licenses and everything activated and installed on my controller, I decided to see if I could remember how to provision a new AP. I pull out one of the new HP 24 port POE switches that I bought and set it up in my office and plugged it in to the network, and then plugged one of my new AP-105s into it. It booted up, got a DHCP address, and I was able to provision it on my controller. Good so far!
    Now it was time to set up that same new HP POE switch as I plan to have it installed in the closet. This is where things started to get a bit hairy.
    I have an HP ProCurve switch on my network that I call my "core" switch. It does all the routing and everything for the VLANS on my network. My Aruba 3600 controller connects directly to this switch. A number of ports on this switch are configured as trunk ports and uplink to other switches on my network. One of these ports was already configured this way and not used any more, so I decided to use that to uplink to my new HP POE switch that my new APs will connect to.
    After doing some research as to how to configure my new POE switch, I got the trunk connection working. I configured port 1 on the new switch as the trunked uplink to my core switch. I set the IP address of the switch to be in VLAN1, and I was able to configure a different port on the switch to be in a different VLAN, and when I connected a laptop to that port it worked exactly as expected. It got a DHCP address in the correct VLAN, and I was able to access different computers in different VLANS, and I was able to access THAT computer from other machines as well.
    So, my final step was to plug in one of my new APs to this port configured for a different VLAN, and this is where things went wrong. The AP would not "check-in" with the controller. It was getting a DHCP address from my DHCP server, as I could see it getting a new lease, but I could not ping the AP nor would it ever show up on the Aruba controller where I could provision it.
    If I use the same switch, but uplink it without using trunks (as I did when I first took it out of the box), everything works fine, no matter what VLAN its plugged into. However, this isn't really the configuration I want.
    So, I guess my question is, how do I make this work? What am I missing here? It doesn't appear to be my switch, because I can plug in a laptop to that port and it works exactly as it should. So, is there something I need to adjust on my Aruba Controller? If so, I have no idea where to even begin looking. What I'm trying to do is already being done with my existing APs at the High School. All traffic from the HS connects to this core switch over a trunk line, so I'm not sure what could be different.
    Thank you all for reading, and if you have any ideas or need any other information from me, please don't hesitate to let me know!
    #3600
  • 2.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 11:45 AM
    This isn't a Procurve forum, but we're all here to help!!!
    Are your switches Procurve E series? I know a bit about these. Are you comfortable posting your core and edge switch (in this test) configurations? Please do so if you are. Also tell us what your NORMAL VLAN is (i.e. the one where the controller IPs live), and any "other" VLAN where you plugged an AP and it didn't work.
    In the first instance, I thought maybe you had a DNS/DHCP discovery problem for the AP. i.e. whenever your controller IPs are in a different VLAN/subnet to the AP in question, you've got to give the AP a way to "find" it's controller. Either by dns lookup of "aruba-master", or DHCP options 43/60. I'm going to assume this isn't your issue, because I think you're saying if you make your edge switch ingress into a core switch port on a different VLAN directly (like a Cisco access port, without a 802.1q tagged config), the AP works ok?
    This makes me think it's a problem with your tagged/trunk uplink config on the switches. But then, I can't understand why a PC would work and route ok if so?!?!
    Just leave your edge switch connected as you'd like, and post your core switch, edge switch and controller config (just the VLAN, port and IP bits). Then tell us from which VLAN the AP works, and does not.
    Cheers.
  • 3.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 11:49 AM
    Oh, forgot to say, make sure you're not falling into the Cisco/Procurve terminology trap...
    Cisco...
    1. A port-channel is an 802.3ad style aggregate connection.
    2. A trunk is and 802.1q tagged (multiple VLAN) link.
    Procurve...
    1. A trunk is an 802.3ad style aggregate connection.
    2. A VLAN tagged link is an 802.1q tagged (multiple VLAN) link. You have to tag it on each VLAN you want it to run.
    i.e. Cisco and Procurve = A "Trunk" is not the same thing!!!
    Cheers.
  • 4.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 02:01 PM
    Thank you for your response! I posted here because I'm still not sure if it's a controller problem or a switch problem, but I appreciate your willingness to help regardless!
    I'll get my configs downloaded and posted here ASAP.
  • 5.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 02:35 PM
    OK, here are my configs. First, here is the "core" switch, This is an HP ProCurve 4204vl
    ; J8770A Configuration Editor; Created on release #L.11.20
    hostname "ShenandoahCore4204"
    module 1 type J8768A
    module 2 type J9033A
    interface B15
       lacp Active
    exit
    interface B16
       lacp Active
    exit
    interface B19
       lacp Active
    exit
    ip routing
    snmp-server community "public" Operator Unrestricted
    vlan 1
       name "DEFAULT_VLAN"
       untagged A1-A3,A7-A12,A14-A24,B2-B4,B6-B16,B18-B24
       ip address 192.168.0.1 255.255.255.0
       tagged A4
       no untagged A5-A6,A13,B1,B5,B17
       exit
    vlan 2
       name "K8Network"
       untagged A13,B1,B17
       ip address 192.168.2.1 255.255.255.0
       ip helper-address 192.168.0.10
       tagged B12-B14,B16,B18-B24
       exit
    vlan 3
       name "HSNetwork"
       untagged B5
       ip address 192.168.3.1 255.255.255.0
       tagged B12-B14,B16-B20,B22-B24
       exit
    vlan 4
       name "WrlsStaff"
       ip address 192.168.4.1 255.255.255.0
       exit
    vlan 5
       name "WrlsStdnt"
       untagged A6
       ip address 192.168.5.1 255.255.248.0
       exit
    vlan 6
       name "GuestWrls"
       ip address 192.168.6.1 255.255.255.0
       exit
    vlan 9
       name "StdntWrls"
       untagged A5
       ip address 192.168.9.1 255.255.252.0
       exit
    ip route 0.0.0.0 0.0.0.0 192.168.0.47
    interface B14
       dhcp-snooping trust
       exit
    interface B24
       dhcp-snooping trust
       exit
    spanning-tree
    spanning-tree priority 0
    password manager
    Here is the config for my new edge POE switch. It is an HP V1910-24G-PoE:
     version 5.20 Release 1108P01
     sysname MS-POESWITCH-01
     domain default enable system
     ip ttl-expires enable
    vlan 1
     description DEFAULT_VLAN
    vlan 2
     description K8Network
    vlan 3
     description HSNetwork
    vlan 4
     description WrlsStaff
    vlan 5
     description ESNetwork
    vlan 6
     description GuestWrls
    vlan 9
     description StdntWrls
    domain system
     access-limit disable
     state active
     idle-cut disable
     self-service-url disable
    user-group system
    local-user admin
     authorization-attribute level 3
     service-type ssh telnet terminal
     stp mode rstp
     stp enable
    interface NULL0
    interface Vlan-interface1
     ip address 192.168.0.170 255.255.255.0
    interface GigabitEthernet1/0/1
     port link-type trunk
     port trunk permit vlan 1 to 6 9
     poe enable
     stp edged-port enable
    interface GigabitEthernet1/0/2
     poe enable
    interface GigabitEthernet1/0/3
     port link-type hybrid
     port hybrid vlan 2 tagged
     port hybrid vlan 1 untagged
     poe enable
    interface GigabitEthernet1/0/4
     poe enable
    interface GigabitEthernet1/0/5
     poe enable
    interface GigabitEthernet1/0/6
     poe enable
    interface GigabitEthernet1/0/7
     poe enable
    interface GigabitEthernet1/0/8
     poe enable
    interface GigabitEthernet1/0/9
     poe enable
    interface GigabitEthernet1/0/10
     poe enable
    interface GigabitEthernet1/0/11
     poe enable
    interface GigabitEthernet1/0/12
     poe enable
    interface GigabitEthernet1/0/13
     poe enable
    interface GigabitEthernet1/0/14
     poe enable
    interface GigabitEthernet1/0/15
     poe enable
    interface GigabitEthernet1/0/16
     poe enable
    interface GigabitEthernet1/0/17
     poe enable
    interface GigabitEthernet1/0/18
     poe enable
    interface GigabitEthernet1/0/19
     poe enable
    interface GigabitEthernet1/0/20
     poe enable
    interface GigabitEthernet1/0/21
     poe enable
    interface GigabitEthernet1/0/22
     poe enable
    interface GigabitEthernet1/0/23
     poe enable
    interface GigabitEthernet1/0/24
     poe enable
    interface GigabitEthernet1/0/25
    interface GigabitEthernet1/0/26
    interface GigabitEthernet1/0/27
    interface GigabitEthernet1/0/28
     ip route-static 0.0.0.0 0.0.0.0 192.168.0.1
     load xml-configuration
    user-interface aux 0
     authentication-mode scheme
    user-interface vty 0 15
    return
     ...and finally, here is the config for my Aruba Controller:
    version 3.3
    country US
    ap regulatory-domain-profile default
      country-code US
      valid-11g-channel 1
      valid-11g-channel 6
      valid-11g-channel 11
      valid-11a-channel 36
      valid-11a-channel 40
      valid-11a-channel 44
      valid-11a-channel 48
      valid-11a-channel 149
      valid-11a-channel 153
      valid-11a-channel 157
      valid-11a-channel 161
      valid-11a-channel 165
      valid-11g-40mhz-channel-pair 1-5
      valid-11g-40mhz-channel-pair 7-11
      valid-11a-40mhz-channel-pair 36-40
      valid-11a-40mhz-channel-pair 44-48
      valid-11a-40mhz-channel-pair 149-153
      valid-11a-40mhz-channel-pair 157-161
    logging level warnings stm
    wms
     general poll-interval 60000
     general poll-retries 3
     general stat-update enable
     general ap-ageout-interval 30
     general sta-ageout-interval 30
     general learn-ap disable
     general persistent-known-interfering enable
    adp discovery enable
    adp igmp-join enable
    adp igmp-vlan 0
    netservice svc-icmp 1
    netservice svc-esp 50
    netservice svc-gre 47
    netservice svc-svp 119
    netservice svc-ftp tcp 21
    netservice svc-ssh tcp 22
    netservice svc-smtp tcp 25
    netservice svc-telnet tcp 23
    netservice svc-dns udp 53
    netservice svc-dhcp udp 67 68
    netservice svc-bootp udp 67 69
    netservice svc-tftp udp 69
    netservice svc-http tcp 80
    netservice svc-kerberos udp 88
    netservice svc-pop3 tcp 110
    netservice svc-ntp udp 123
    netservice svc-msrpc-udp udp 135 139
    netservice svc-msrpc-tcp tcp 135 139
    netservice svc-snmp udp 161
    netservice svc-snmp-trap udp 162
    netservice svc-smb-udp udp 445
    netservice svc-smb-tcp tcp 445
    netservice svc-https tcp 443
    netservice svc-ike udp 500
    netservice svc-rtsp tcp 554
    netservice svc-nterm tcp 1026 1028
    netservice svc-l2tp udp 1701
    netservice svc-pptp tcp 1723
    netservice svc-sccp tcp 2000
    netservice svc-natt udp 4500
    netservice svc-vocera udp 5002
    netservice svc-sip-udp udp 5060
    netservice svc-sip-tcp tcp 5060
    netservice svc-sips tcp 5061
    netservice svc-adp udp 8200
    netservice svc-papi udp 8211
    netservice svc-cfgm-tcp tcp 8211
    netservice svc-syslog udp 514
    netservice svc-noe udp 32512
    netservice svc-noe-oxo udp 5000 alg noe
    netservice svc-http-proxy1 tcp 3128
    netservice svc-http-proxy2 tcp 8080
    netservice svc-http-proxy3 tcp 8888
    netservice svc-h323-tcp tcp 1720
    netservice svc-h323-udp udp 1718 1719
    netservice svc-v6-icmp 58
    netservice svc-v6-dhcp udp 546 547
    ip access-list session control
     user any udp 68 deny
     any any svc-icmp permit
     any any svc-dns permit
     any any svc-papi permit
     any any svc-cfgm-tcp permit
     any any svc-adp permit
     any any svc-tftp permit
     any any svc-dhcp permit
     any any svc-natt permit
    ip access-list session logon-control
    ip access-list session ap-acl
     any any udp 5000
     any any udp 5555
     any any svc-gre permit
     any any svc-syslog permit
     any user svc-snmp permit
     user any svc-snmp-trap permit
     user any svc-ntp permit
    ip access-list session allowall
     any any any permit
    ip access-list session captiveportal
     user alias controller svc-https dst-nat 8081
     user any svc-http dst-nat 8080
     user any svc-https dst-nat 8081
     user any svc-http-proxy1 dst-nat 8088
     user any svc-http-proxy2 dst-nat 8088
     user any svc-http-proxy3 dst-nat 8088
    ip access-list session cplogout
    ip access-list session vpnlogon
     user any svc-ike permit
     user any svc-esp permit
     any any svc-l2tp permit
     any any svc-pptp permit
    ip access-list session srcnat
     user any any src-nat
    ip access-list session sip-acl
     any any svc-sip-udp permit queue high
     any any svc-sip-tcp permit queue high
    ip access-list session svp-acl
     any any svc-svp permit queue high
     user host 224.0.1.116 any permit
    ip access-list session vocera-acl
     any any svc-vocera permit queue high
    ip access-list session noe-acl
     any any svc-noe permit queue high
    ip access-list session skinny-acl
     any any svc-sccp permit queue high
    ip access-list session h323-acl
     any any svc-h323-tcp permit queue high
     any any svc-h323-udp permit queue high
    ip access-list session dhcp-acl
    ip access-list session icmp-acl
    ip access-list session tftp-acl
    ip access-list session dns-acl
    ip access-list session http-acl
     any any svc-http permit
    ip access-list session https-acl
     any any svc-https permit
    ipv6 access-list session v6-logon-control
     any any svc-v6-icmp permit
     any any svc-v6-dhcp permit
    ipv6 access-list session v6-dhcp-acl
    ipv6 access-list session v6-icmp-acl
    ipv6 access-list session v6-dns-acl
    ipv6 access-list session v6-http-acl
    ipv6 access-list session v6-https-acl
    ipv6 access-list session v6-allowall
     any any any permit
    user-role authenticated
     session-acl allowall
     ipv6 session-acl v6-allowall
    user-role default-vpn-role
    user-role logon
     session-acl logon-control
     session-acl captiveportal
     session-acl vpnlogon
     ipv6 session-acl v6-logon-control
    user-role guest-logon
     captive-portal default
    user-role ap-role
     session-acl control
     session-acl ap-acl
    user-role voice
     session-acl sip-acl
     session-acl noe-acl
     session-acl svp-acl
     session-acl vocera-acl
     session-acl skinny-acl
     session-acl h323-acl
     session-acl dhcp-acl
     session-acl tftp-acl
     session-acl dns-acl
     session-acl icmp-acl
    user-role guest
     session-acl http-acl
     session-acl https-acl
     session-acl dns-acl
     ipv6 session-acl v6-http-acl
     ipv6 session-acl v6-https-acl
     ipv6 session-acl v6-dhcp-acl
     ipv6 session-acl v6-icmp-acl
     ipv6 session-acl v6-dns-acl
    aaa server-group default
     auth-server Internal
     set role condition role value-of
    aaa authentication vpn default-role default-vpn-role
    mgmt-role read-only
     description "This is the Default View Only Role"
     permit view-only
    crypto isakmp policy 20
      encryption aes256
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto dynamic-map default-dynamicmap 10000
      set transform-set default-transform default-aes
    wms
     valid-11b-channel 1 mode enable
     valid-11b-channel 6 mode enable
     valid-11b-channel 11 mode enable
     valid-11a-channel 36 mode enable
     valid-11a-channel 40 mode enable
     valid-11a-channel 44 mode enable
     valid-11a-channel 48 mode enable
     valid-11a-channel 149 mode enable
     valid-11a-channel 153 mode enable
     valid-11a-channel 157 mode enable
     valid-11a-channel 161 mode enable
     valid-11a-channel 165 mode enable
    hostname Aruba3600
    interface vlan 1
      ip address 192.168.0.20 255.255.0.0
    ip default-gateway 192.168.0.47
    localip 0.0.0.0 ipsec xxx
    clock timezone CST -6 0
    mgmt-user admin root xxx
    enable secret "xxx"
    trusted all
     The IP address for my controller is 192.168.0.20, and I have a DNS entry for "aruba-master" pointing to that. The port on the core switch I'm uploading to is B19. The uplink port on the edge POE switch is port GigabitEthernet1/0/1. The port I'm setting up for the AP is GigabitEthernet1/0/3. Right now I have a laptop plugged into that port, and it's working perfectly. I get a DHCP address for VLAN2, and I can ping servers in VLAN1 and get to the internet.
    Please let me know if there is any other info from me that may help! Thank you!
  • 6.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 07:37 PM
    Does your DHCP server has a domain name for the IP Scope where you want to configure the new AP?  Usually if you're using DNS for the APs to find the controller the DHCP scope needs the domain name so it can resolve "aruba-master.<your_domain>".
    It sounds like you have the network piece configured correctly.  I would assume that if you plug in a laptop on the new switch, get an IP address, you can ping/access the controller.  If this is the case, then I would venture to say your network piece is configured to allow L3 connectivity between the sites.
    -Mike
  • 7.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 11:46 PM
    Yes, I do have the domain name in my DHCP server. In fact, one of the first things I checked when I plugged my laptop into that port was a ping to "aruba-master", and it appended the ".domain.name" to the end of it and resolved to the correct address.
    So, if my network is configured properly, then does that mean my problem is somewhere in the configuration of my Aruba controller? I hooked up a cable to the console port of the AP I was working with to see if there were any errors, I can try to hook that up again and let you know what happens, if that would help.
  • 8.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 11:51 PM
    Mister Vertigo,
    If it is a domain laptop, it might automatically append <domain name>, even though it is not configured in your DHCP server.  If you can, please plug in a non-doman device and see if the domain is being received through DHCP.
  • 9.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 08, 2012 11:57 PM
    Good point. I'll try this when I get back to the office in the morning.
  • 10.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 03:59 AM
    Yeah, I'd agree with the other guys. The switches look ok on the face of it at a glance.
    What you can do (if your AP has a console port (125 and 105 do for example)), is plug the console into the AP during boot. Look at the outputs. It's pretty obvious what's going on in terms of controller discovery.
    Cheers.
  • 11.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 09:45 AM
    It looks like the domain (option 015) is set properly in DHCP, so I don't think that is the issue.
    Here is the output when I plug in to the console on the AP-105 during boot:
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
    Retry count exceeded; starting again
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
     The DHCP retry repeats over and over again for a while, until the device finally reboots and tries again. However, on my DHCP server, I can see where this device did in fact get a DHCP lease. I'm pretty sure my DHCP is set up OK because my existing APs in the other building have been working fine, and one of the new ones was working OK before I configured the trunk ports on the switch.
    Hopefully this output from the AP helps. Thank you all for your help!
  • 12.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 09:47 AM
    Delete the lease and see if it gets one again. That might have been historical...
  • 13.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 09:48 AM
    I actually did just that before I even booted it up this morning.
  • 14.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 09:55 AM
    Do the AP doesn't seem to be getting the DHCP.
    I think you said you confirmed that a laptop connecting to the same port as the WAP is getting a DHCP address.  Is this correct?  If not, can you verify that a laptop connecting to the port where the WAP is does indeed get an IP and has L3 connectivity to the controller?
    A few other things:
    - It seems all your ports on the POE Switch is setup for edge mode.  Do verify this is true on the port where the WAP is.
    - Which VLAN should the WAP be in on the POE switch?
    - Which port do you have the WAP connected to on the POE switch?
    - Is the power for the WAP in the correct VLAN?
    -Mike
  • 15.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 10:15 AM
    Yes, the laptop plugged into the exact same port where the AP is plugged into works just fine. It gets a DHCP lease, gets the address, and can access everything on my network. I can ping aruba-master, and can get out to the internet.
     - Ports as edge mode: I'll be honest, I don't even know what that means. But, looking at the config I posted above I see "stp edged-port enable" listed under every port on the switch
     - Which VLAN: Ultimately, I'll probably put the APs in VLAN1, but right now I'm trying to get it to work on ANY VLAN and not having any luck. I still want to trunk the uplink though because I may have other devices on this switch that I will want in other VLANS at some point.
     - The WAP is on port 3
     - Power for the WAP in the correct VLAN: I have no idea how to set this, or that it was even an option. How do I check this?
  • 16.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 10:22 AM
    I meant port instead of power in my last question. :)
    So one difference I see on port g1/0/3 is that it's a hybrib link.  Not sure what that means in HP's term but it seems it can support both tagged and untagged VLAN.
     poe enable
    Based on the above config and if I am reading the configuration correctly, your WAP and laptop should get an IP in the VLAN1. Is this true?
    What I would do is move the WAP to port g1/0/4, which should be in VLAN1 by default.  You should be able to determine the VLAN by issuing "show vlan" (assuming this is the command to do that).  Try on port g1/0/4 and see if the WAP works.  Not sure if you tried this already or not.
    Since the DHCP server and the WAP would be in VLAN1, you do not need the IP-HELPER address on the core end for VLAN1.
    -Mike
  • 17.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 10:44 AM
    Ah, ok, that makes sense!
    With the config you quoted, the laptop plugged in to that port get an IP address from DHCP on VLAN2
    I did find one thing in my current config that was not in the one I posted. Here is the part for that port:
     port hybrid pvid vlan 2
     poe enable
     The "port hybrid pvid vlan 2" is in there as well, and I have to have that in there for the port to work on that VLAN. I get the same results on my WAP with this in there.
    Also, I tried plugging the WAP into port 4 which has no VLAN configuration on it at all, so it should default to VLAN1, and I get the same results as above too. I see the device getting a lease on my DHCP server, but the WAP never boots.
  • 18.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 11:04 AM
    Well, when you plug the laptop on port g1/0/3 you get an IP in VLAN2.  When you plug the laptop on port g1/0/4, which VLAN do you get an IP in, assuming the laptop is working?
    As Colin suggested, you may need to get a packet capture of the traffic on the DHCP server.
    One other thing to try, is to assign a static IP on the WAP from the console and see if it's able to connect.  Search the forum or the KB to do this.  If you don't find it, let me know and I'll get it for you.  This would take the DHCP variable and at least you can verify your network connectivity specific for the WAP.
    Are the ports where the WAP is working in the other buildilng configured similar to port g1/0/3?
    -Mike
  • 19.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 11:28 AM
    OK, I statically set the IP address for the WAP. From the command line of the WAP I can ping the IP address of the controller, as well as other devices in different VLANs, including the internet. When I try to boot it though, it still tries to connect to DHCP and I don't know how to keep it from doing that.
  • 20.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 11:34 AM
    Ah, OK, I got the AP to boot by typing tftpboot. It came up and showed up on my controller where I could provision it.
    So, does that mean I have a DHCP problem?
  • 21.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 11:51 AM
    Seems like it.  It's strange you get an IP on the laptop but not the WAP.  Without having a capture can't help you much more with the DHCP problem.
    I would definitely review your DHCP configuration and try to get a capture of the DHCP traffic to/from the WAP.
    -Mike
  • 22.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 11:55 AM
    OK, when it worked I had the WAP plugged in to port 6 on the swtich, which was not configured for any VLAN, so the static IP I gave it was in VLAN1, the default, and the same VLAN as the controller.
    I tried it again by putting the WAP on port 3 again, which is set up for VLAN2. When I change the IP address and gateway on the WAP for that VLAN, it cannot communicate with the controller, or even the VLAN's gateway IP.
  • 23.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 12:01 PM
    VLAN2 is configured as a TAG VLAN, meaning the WAP would need to be TAG as well and it's not.  The WAP required an UNTAG port/VLAN.  I imagine the ports that do not have a VLAN entry defaults to VLAN1.  You should be able to view this by issuing "show vlan" from the CLI on the network switch.
    I'm not familiar with HP switches to say that your configuration on port g1/0/3 is correct.  I'm not sure why you have a TAG VLAN and and UNTAG VLAN on the same port.  That was why I recommended you use a port that doesn't have the added configuration.  At least if you try with VLAN1, it should all work and then maybe you can determine if you have a switch port configuration issue.
    For the WAPs that you have in another building, how are the switch ports configured?  Can you post a snapshot of one of the port configuration where you have an existing WAP in another building?  Also, it would be helpful if you can identify which VLAN a WAP that is working in another building with DHCP is on.
    -Mike
  • 24.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 12:23 PM
    OK, I figured it out. Your line of questioning got me to my answer!
    You asked how my ports were configured on the other switch where they are working, and I discovered that those ports are UNTAGGED, not tagged. So, on my new switch I changed it from being tagged in VLAN3 to untagged, and it booted up perfectly with DHCP and everything.
    Thank you all SO MUCH for your patience and your help. You guys didn't have to help me, as it ended up not being a real Aruba issue, but you did anyway, and you got me going! Thank you!
  • 25.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 12:37 PM
    Glad you found your problem. :-)
    -Mike
  • 26.  RE: Setting up APs in New Building - VLANs, Trunks, DHCP, oh my!
    Posted May 09, 2012 09:49 AM
    You might need to do a packet capture at the dhcp server to find out what is happening.
