Setting up external SFTP server in CPPM
  • 1.  Setting up external SFTP server in CPPM
    Posted Mar 14, 2018 01:51 PM
    So I thought this should have been a simple enough task has turnned out to be a nightmare.
    Im trying to get the external server in CPPM to work so the backups can be sent automatically.  The configuration seems to be straight forward...
    Host IP, username, password remote directory
    but each time the backup runs I get the following error message
    Error reading SSH protocol banner
    all of my other SFTPs work to this server with no problem.  I have even tried sending the file to a different server and get the same error.  Has anyone else experienced this problem and if so what was the solution or work around.
  • 2.  RE: Setting up external SFTP server in CPPM
    Posted Mar 14, 2018 02:08 PM
    What do the logs on the SFTP server show?
    Which version of ClearPass?
  • 3.  RE: Setting up external SFTP server in CPPM
    Posted Mar 14, 2018 04:56 PM
    The version is 6.7.0.101814....Im trying to get the logs since the server is managed by a different group.  I will post as soon as I get them.
  • 4.  RE: Setting up external SFTP server in CPPM
    Posted Mar 14, 2018 10:44 PM
    Hi Don,
    I'm also using ClearPass 6.7.0 and has issue with auto backup configuration to an external server (except that I'm using SCP, and the log message was something related to FIPS mode). I opened a TAC case and they have confirmed it's a bug, promising it'll be fixed in upcoming patch of 6.7.X. Hope this information is useful for you.
  • 5.  RE: Setting up external SFTP server in CPPM
    Posted Mar 15, 2018 09:53 AM
    Appreciate the feed back, it does let me know that some times things are not always as simple as they seem.   I opened a case as well and at this point they dont have an answer for me.
  • 6.  RE: Setting up external SFTP server in CPPM
    Posted Mar 16, 2018 09:19 AM
    So I had a chance to speak to the server team regarding the logs and there is nothing in the logs because the connection is failing prior to it asking for user credentials.
  • 7.  RE: Setting up external SFTP server in CPPM
    Posted Mar 16, 2018 10:07 AM
    We have issue related to auto backup when FIPS is enabled on clearpass but it is working fine in other cases.
    Are you using sloarwinds SFTP/freeFTPd server or any other software in the client machine.
    We have done the following the File Server configuration in CPPM and freeFTPD, the transfer is succeed without any error.
    Please configure the following at your end,
    2. freeFTPD Settings
    Step 1: Create a folder in the windows desktop manually & The folder name should be your CPPM machine IP.
    Step 2: Open the freeFTPD tool by right clicking & Run as administrator
    Configure each tab as follows and click Apply Save ,
    2.Users
    Click the Add ... button
    Configure as follows, give the same username/password what have given in the CPPM
    Host Restrication
    Logging
    freeFTPD-EnableLogging.PNGg
    2. Run the following auto backup script manually in the terminal,
