Setting up IAP 105
  • 1.  Setting up IAP 105
    Posted Sep 17, 2014 01:37 PM
    We have 16 no. IAP 105 connected in our building. Total no of users are 700. Can we assign all 700 username and password ?
  • 2.  RE: Setting up IAP 105
    Posted Sep 17, 2014 01:51 PM
    Ideally, they'd be logging with a username/password from an external RADIUS system through an 802.1X enabled network.   Review the following for some additional thoughts:
    http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/Authentication/AuthenticationMethods.htm?
  • 3.  RE: Setting up IAP 105
    Posted Sep 17, 2014 03:34 PM
    As I remember, there is limit up to 512 users in Instant internal database, so the answer is NO. You can connect to any external database/catalog service (RADIUS/LDAP).
    Marek
