In our current wireless set-up we have created a lot of Layer-2 connected high-availability controller clusters. Where each separate controller is connected to a switch with layer 2 and layer 3 functionality. These switches are in the same site-location and are layer-2 connected and so the layer-2 connection between the controllers in the cluster is established. This works fine.
All controllers are so called MD's managed by Mobility Master.
But now we would like to make a Layer-2 high-availability cluster with Aruba controllers that are in different site-locations. And the switches which these controllers are connected to don't have a Layer-2 connection between them. So our normal way of forming a Layer-2 cluster between controllers isn't possible in this case.
What we can do, by using a dark fiber that's available between the two site-locations, is connect both the controllers directly to each other using this physical link.
Question: is it possible to connect the controllers in this way uysing the dark-fiber link and establishing a Layer-2 controller cluster in that way?
By the way: Our Mobility Master and controllers are running on Aruba OS 8.5.0.3 currently.
