Setting up Wireless Printer. Help !!!
  • 1.  Setting up Wireless Printer. Help !!!
    Posted May 14, 2015 09:46 AM
    Dear All,
    I want to connect wireless printer on my WLAN. Single SSID vlan assingment is set to default and ip assignment from virtual controller DHCP. When I get connect my wireless printer on WLAN it will get an ip address from virtual controller DHCP but that ip is not pingable. Moreover the same ip is unable to access from the browser. However user ip addresses are pingable.
    SSID-> ABC and rule on this SSID is Allow any to all destination.
    Help !!!
  • 2.  RE: Setting up Wireless Printer. Help !!!
    Posted May 14, 2015 09:49 AM
    HI,
    Can you sahre the output of "show user-table" after connecting the printer to the wifi. it will help us to to know which role is assigned to the printer .
    Please get the above required output.
