Setting up WMM
  • 1.  Setting up WMM
    Posted May 25, 2017 02:49 PM
    Im looking to setup WMM nder the vap profile "GUEST" I see WMM traffic management, I created and enabled a profile called "GUEST WMM"
    Then, under the SSID profile of "GUEST" I see a WMM checkbox, do i need to check that to enable WMM?
  • 2.  RE: Setting up WMM
    Posted May 25, 2017 02:53 PM
    If you have a SSID that supports 892.11n or 802.11ac, WMM is automatically enabled and is part of those protocols...
  • 3.  RE: Setting up WMM
    Posted May 25, 2017 02:58 PM
    Well that makes it easy. So I dont have to check any boxes or make any traffic managent profiles?
    Is there anything else I need to know, like if I edit the EDCA values, do those take effect?
  • 4.  RE: Setting up WMM
    Posted May 25, 2017 03:32 PM
    You don't have to set anything up.  The question is, what are you trying to do?
  • 5.  RE: Setting up WMM
    Posted May 25, 2017 03:56 PM
    I was going through a VRD and it was talking about setting up WMM. Just trying to optimize.
  • 6.  RE: Setting up WMM
    Posted May 26, 2017 11:59 AM
    Are you trying to optimize or should I say prioritize traffic (voice/video)? Configure DSCP values?
