Setup Aruba AP 175 via usb console (aten rs232)
  • 1.  Setup Aruba AP 175 via usb console (aten rs232)
    Posted Oct 20, 2014 11:40 PM
    i want to setup aruba ap 175 via usb console with usb console aten rs232? does it work?
  • 2.  RE: Setup Aruba AP 175 via usb console (aten rs232)
    Posted Oct 21, 2014 09:59 AM
    You'll need a controller for the AP-175. If you have one then you can set parameters from the command line such as its ip addressing information and its master controller ip. Typically we would recommend using DHCP with DNS Discovery, ADP (Layer 2) discovery, or DHCP Option 43 Discovery. This simplifies the initial AP setup immensely.
    If you don't have a controller you'll need to get the IAP-175 that runs the instant code, which can be used without a standard mobility controller and instead has a built in virtual controller.
