setup epa-tls with oscp but no auth source on clearpass
This thread has been viewed 29 times
  • 1.  setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 06, 2021 05:52 AM
    Hi
    Anyone done this before? We only want clearpass to check if cert is OK
    Sebastian Johansen
  • 2.  RE: setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 06, 2021 10:19 AM
    Yes, this is the most common deployment.
    Tim C
  • 3.  RE: setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 07, 2021 01:23 AM
    Oh how about that, you don't have an step by step setup for this? Fiarly new to clearpass
    Sebastian Johansen
  • 4.  RE: setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 07, 2021 02:59 AM
    The setup is actually very simple, you just have to allow authentication based on details of the certificate.
    Have you already start building this? or you stuck somewhere in the process?
    There is a good explanation of different steps, including 802.1X configuration is this document:
    Aruba ACEX #105 (ACCX/ACDX/ACMX) | Master ASE | Consultant @ PQR
  • 5.  RE: setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 07, 2021 03:23 AM
    Most important step is to create a new EAP-TLS Authentication method that has Authorization disabled (and OCSP enabled). The Authorization required option controls if a check is done to an authentication source.
  • 6.  RE: setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 07, 2021 05:08 AM
    Thanks, removed the authorization required now.
    On the service part, which authentication sources should we have? Currently is sat to "local user repository"
    Sebastian Johansen
  • 7.  RE: setup epa-tls with oscp but no auth source on clearpass
    Posted Apr 07, 2021 05:46 AM
    Local User Repository is fine, in fact, I recently found out that when using EAP-TLS without authorization, you can even leave the authentication sources empty. But before, I just put in something like Local Users or Endpoint Repository, as it is not used anyway.
