Sever rule to set VLAN to a named VLAN instance
  • 1.  Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 06:06 AM
    Hi All,
    We have 2 controllers running in a master - master scenario and a multitude of local controllers. Each local controller has 2 local VLANs for the different 2 user types. The local VLANs vary, some are the same, some are unique. The domain name of each user type is static across all sites.  (2 domains on per user type / group)
    Lets say the user groups are A and B and the domais are alpha.com and beta.net.
    To simplify thing I want to authenticate all users against a central AD server (802.1x auth) and using a server rule to read the domain-name attribute and to assign a VLAN name rather than number.
    So the rules would be :
    #set vlan condition Domain-Name equals alpha.com set-value A
    #set vlan condition Domain-Name equals beta.net set-value B
    The named VLAN can then have a different ID on the local controllers.
    However I'm unable to set the VLAN to be a name via this method as it only accepts the VLAN ID.
    It is possible to do this?
  • 2.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 06:07 AM
    A Vlan name cannot be used in a server derivation rule.
  • 3.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 06:28 AM
    Ah ok that's a shame.
    I'll have to think of another solution!
  • 4.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 01:18 PM
    Infact you can achieve this :
    I mean to say Named-vlan is supported under SDR.
    (Aruba3600) #show aaa derivation-rules server-group test
    Server Group
    Name   Inservice  trim-FQDN  match-FQDN
    surya  Yes        No
    Server Rule Table
    Priority  Attribute  Operation  Operand    Action    Value  Total Hits  New Hits  Description
    1         User-Name  contains   surya.com  set vlan  ten    2           2
    Rule Entries: 1
    (Aruba3600) #show vlan mapping
    Vlan Mapping Table
    VLAN Name  Pool Status  Assignment Type  VLAN IDs
    ten        Disabled     N/A              10
    (Aruba3600) #
  • 5.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 01:19 PM
    Shabaresha,
    What version of code is this supported in?
  • 6.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 01:26 PM
    not sure when we started supporting this. but we have this support in couple of releases back.
  • 7.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 02:01 PM
    Shabaresha, thank you.
  • 8.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 08, 2011 02:56 PM
    Excellent. Many thanks for letting me know.
    Now I just need to see if i can configure this on a matter controller then have the named vlan have a different vlan id on local controllers. Should be ok right?
  • 9.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Dec 09, 2011 12:25 AM
    yes ..
  • 10.  RE: Sever rule to set VLAN to a named VLAN instance
    Posted Nov 29, 2016 11:23 AM
    I come across your post while researching a similar issue. We have a single SSID, and they users authenticate using a captive portal through ldap. Two users groups are from different domains. I want to know if you were to resolve your issue using the named VLAN instances.
