Several instant vpn
  • 1.  Several instant vpn
    Posted Jan 20, 2015 11:55 AM
    Hi guys!
    Hope you are doing well! I would like to deloy a WLAN network on two campus.
    - the first campus will have 60 AP
    - the second campus will have 35 AP
    The two campus networks are connected to a centralized datacenter via a layer 3 network.
    I would like to have 2 instant AP clusters on the first campus (30 AP on each cluster) and 1 instant APs cluster on the second campus (35 AP on each cluster). As I have the DHCP server and the hotspot management solution (for the captif portal) on the main datacenter, I would like to tunnel all the user trafic to the Datacenter via L2TP/IPsec VPN. thus, I will have a centralized Aruba controller on the datacenter to terminate the VPNs. I'm wondering about two things however:
    1) Can I have two Instant AP cluster on the same location (the first campus for instance) and use two VPNs from this location to the main controller?
    2) Do I have to configure the NAT-T at each campus router/Firewall?
    May thanks for your help !
