SHA2 certificate upgradation in CPPM
  • 1.  SHA2 certificate upgradation in CPPM
    Posted Sep 22, 2016 02:38 AM
       We are planning for a Server certificate migration from SHA 1 to SHA 256.
      I am totally new to this and have no idea about how to set this up,
    Can i get some good tips to do this activity.
    We currently have our Server running with SHA1.All clients are using SHA 1 for authentication.
    Thanks in advance.
    Regards
  • 2.  RE: SHA2 certificate upgradation in CPPM
    Posted Sep 22, 2016 05:02 AM
    Your question is very open-ended.  What encryption and authentication are your clients using?
    Information on how to import a new server certificate on clearpass is here:  http://www.arubanetworks.com/techdocs/ClearPass/Aruba_CPPMOnlineHelp/index.htm#CPPM_UserGuide/Admin/ServerCertificateHelp.html
  • 3.  RE: SHA2 certificate upgradation in CPPM
    Posted Sep 22, 2016 11:52 PM
    Thanks Collin for sharing the info.
    For the missing info below are the points:
    * Currently the endpoits are using SHA1
    * Currently Client is using RADIUS authentication.
    * I am not aware how to find the encryption, ur guidenece will be helpful
    I have few other doubts also:
    * If we import SHA2 certificate in CPPM will the CPPM still uses SHA1 for endpoints not having SHA2 installed?
    * Also how to verify SHA2 migration is succesful and working succesfully
    * How to Roll back if my SHA2 migration fails in CPPM
    Thanks in advance
  • 4.  RE: SHA2 certificate upgradation in CPPM
    Posted Sep 23, 2016 05:01 AM
    In General:
    - The important thing is that your clients trust the new server certificate.  Whoever setup the system would know what mechanism they use to configure clients trusting the server certificate.
    - If you configure a SHA-2 certificate on CPPM, that is what clients will be using.
    - You should export the current ClearPass radius server certificate, so that you can import it later, just in case the import of the SHA-2 certificate does not work.
    Please contact Aruba TAC to work out the specifics of what you are trying to do, to ensure a successful migration.
  • 5.  RE: SHA2 certificate upgradation in CPPM
