Show all references to cert on controller?
This thread has been viewed 23 times
  • 1.  Show all references to cert on controller?
    Posted Aug 11, 2016 06:31 PM
    Quick question, first post,
    Is there a way in the web gui or cli to show the references to a certificate on an aruba controller?  In the certificates page, it is helpful to see how many times a cert is referenced, but if only that number were a hyperlink to another page showing those reference locations.  This isn't just for the sake of deleting the certificate, but so i can reproduce the desired result of one controller to another, and I've forgotten where and why I referenced a trusted certificate.
  • 2.  RE: Show all references to cert on controller?
    Posted Aug 11, 2016 06:33 PM
    They will be referenced by name anywhere they're used in the CLI.
  • 3.  RE: Show all references to cert on controller?
    Posted Aug 11, 2016 06:40 PM
    right, also the web ui, but the 'anywhere they're used' is what i'm looking for.  I don't want to dig around all the AAA profiles i've created testing different things to find which one uses the cert to terminate dot1x on the controller, I want to be brought to that reference.
  • 4.  RE: Show all references to cert on controller?
    Posted Aug 11, 2016 06:46 PM
    You can do show run and hit the W key and put in the certificate name and it will take you to all references.
  • 5.  RE: Show all references to cert on controller?
    Posted Aug 12, 2016 09:41 AM
    Fantastic! thank you very much, integration of that into the web ui would be slick
