I have dual-band APs (125 & 105) running in air monitor mode on the 2.4 radios and ap mode on the 5.0 radios. When invoking "show ap arm neighbors ip-addr <ap ip address>", I am seeing only the neighbors from the 5.0 radio. Shouldn't I be seeing neighbors on the 2.4 band as well?
Though ome controllers are running versions 3.4.2.5 of AOS, while others are running 6.1.2.6, the result is still the same for the 2.4 AM access points-neighbors on 5.0, and nothing on 2.4.
Thanks in advance,
John
