show ap association band steer output
  • 1.  show ap association band steer output
    Posted May 12, 2016 12:24 PM
    At the end of the "show ap association ap-group XXXXXX"  You get an output of "Band steer moves (T/S).  What does the output mean (T/S)?  Example :  996/779
    Arabia Mtn HS-3-002  40:e3:d6:bc:c4:71  70:48:0f:60:43:a6  y     y      2    20     Employee-Access  911      0x10337    a-VHT-80sgi-2ss  9m:25s         1          WAB    996/779
  • 2.  RE: show ap association band steer output
    Posted May 12, 2016 01:50 PM
    T=Tried S=successful.
    Why are you doing 80mhz channels?  I know it is the default, but....
  • 3.  RE: show ap association band steer output
    Posted May 12, 2016 03:03 PM
    I am using the 80 because it is on by default.  What should I be doing? And how do I change it?  I do have a very dense deployment not by my choice.  Is there some documentation I can read?
  • 4.  RE: show ap association band steer output
    Posted May 12, 2016 03:11 PM
    In your ARM profile, you should change the "Allowed Bands for 40mhz channels" to "None" and uncheck 80mhz support:
    http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/ARM/ARM_Profiles.htm?
    If you do show ap active right now, your channels will have an E, meaning 80 mhz.  There are only two channels in the 80mhz spectrum if you are not doing DFS and 4 channels if you allow DFS, but that is still not enough.  If you change "allowed" to "none" and uncheck 80mhz channels, that would give you 9 non-overlapping channels to play with, and improve your performance.
    Please see here:  http://community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
  • 5.  RE: show ap association band steer output
    Posted May 13, 2016 04:20 PM
    Thanks for the feedback.  After reading the articles and the post.  I better understand the out put of the CLI command.  The output makes more sense to me now.  I am a K12 with very dense AP installed.  There is an AP in the hallway 1 per 2 rooms and now an AP in every classroom.  I am in the process of adding Air Monitors and Spectrum monitors in all 150 schools.  I am not sure if this should be per site or allow the controllers to set the Air Monitors.
    Cross Keys HS-A-001 04:bd:88:48:33:90 c8:f6:50:1c:02:84 y y 21 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-2ss 1m:19s 1 WAB 19/5
    Cross Keys HS-A-001 04:bd:88:48:33:90 90:b2:1f:45:2b:79 y y 37 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-1ss 2m:12s 1 WAB 7/1
    Cross Keys HS-A-001 04:bd:88:48:33:80 c8:f6:50:1c:00:79 y y 7 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 8m:18s 1 WAB 40/3
    Cross Keys HS-A-001 04:bd:88:48:33:90 80:be:05:b1:bf:22 y y 47 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-2ss 23h:51m:55s 1 WAB 14/7
    Cross Keys HS-A-001 04:bd:88:48:33:80 28:e3:47:e0:f4:0c y y 11 10 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 59m:2s 1 WAB 9/8
    Cross Keys HS-A-001 04:bd:88:48:33:90 90:b2:1f:44:63:78 y y 25 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-1ss 10m:30s 4 WAB 3/1
    Cross Keys HS-A-001 04:bd:88:48:33:90 b0:65:bd:dc:ed:f5 y y 43 20 DCSD.Secure 911 0x101c0 a-HT-20-1ss 2m:50s 9 WAB 19/0
    Cross Keys HS-A-001 04:bd:88:48:33:90 b0:65:bd:de:78:34 y y 27 20 DCSD.Secure 911 0x101c0 a-HT-20-1ss 3m:51s 1 WAB 25/2
    Cross Keys HS AP-4 Media 6c:f3:7f:2e:40:58 90:b2:1f:43:fc:40 y y 8 20 DCSD.Secure 911 0x10a9f a-HT-40sgi-1ss 2m:20s 8 WAB 29/7
    Cross Keys HS-A-001 04:bd:88:48:33:90 90:b2:1f:44:ef:01 y y 39 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-1ss 1m:39s 12 WAB 8/4
    Cross Keys HS-4-004 04:bd:88:44:38:30 10:4a:7d:35:cd:34 y y 4 250 DCSD.Secure 911 0x104f8 a-VHT-40sgi-2ss 1h:1m:41s 1 WAB 2/1
    Cross Keys HS-4-014 04:bd:88:48:41:b1 1c:ab:a7:09:c1:dc y y 3 10 airwatch 911 0x105fd a-HT-20-1ss 23h:56m:13s 1 WAB 0/0
    Cross Keys HS-A-001 04:bd:88:48:33:80 80:be:05:b1:75:5b y y 17 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 7m:35s 1 WAB 52/3
    Cross Keys HS-4-006 04:bd:88:44:2c:72 90:b6:86:83:91:f6 y y 1 10 Employee-Access 911 0x107b5 a-VHT-40sgi-2ss 12m:26s 1 WAB 32/13
    Cross Keys HS-A-001 04:bd:88:48:33:80 80:be:05:b1:74:6e y y 23 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 7m:13s 1 WAB 18/2
    Cross Keys HS-4-002 04:bd:88:44:36:d0 b0:65:bd:e2:84:29 y y 19 20 DCSD.Secure 911 0x103b7 a-HT-20-1ss 2h:32m:32s 1 WAB 46/0
    Cross Keys HS-A-001 04:bd:88:48:33:90 90:b2:1f:41:62:48 y y 50 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-1ss 9m:29s 1 WAB 9/3
    Cross Keys HS-3-008 04:bd:88:44:47:a0 38:59:f9:a1:b8:b4 y y 1 10 DCSD.Secure 911 0x109c6 g-HT-20sgi-1ss 1m:23s 1 WA 0/0
    Cross Keys HS-A-001 04:bd:88:48:33:90 b0:65:bd:d7:f6:be y y 7 20 DCSD.Secure 911 0x101c0 a-HT-20-1ss 3m:14s 3 WAB 7/2
    Cross Keys HS-A-001 04:bd:88:48:33:80 c0:f2:fb:01:f2:ee y y 24 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 7m:10s 1 WAB 86/12
    Cross Keys HS-A-001 04:bd:88:48:33:80 c8:f6:50:1b:21:b5 y y 4 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 2m:20s 2 WAB 19/2
    Cross Keys HS-A-001 04:bd:88:48:33:80 c8:f6:50:1b:f8:0e y y 1 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 29s 4 WAB 36/3
    Cross Keys HS-1-002 04:bd:88:48:3c:c2 c8:6f:1d:47:ae:f7 y y 1 20 Employee-Access 911 0x10862 g-HT-20sgi-1ss 9m:56s 1 WAB 15/9
    Cross Keys HS-4-014 04:bd:88:48:41:b1 1c:ab:a7:03:13:29 y y 5 10 airwatch 911 0x105fd a-HT-20-1ss 23h:56m:12s 1 WAB 0/0
    Cross Keys HS-A-001 04:bd:88:48:33:90 a4:d1:d2:65:00:95 y y 30 10 DCSD.Secure 911 0x101c0 a-HT-20-1ss 1h:9m:49s 1 WAB 17/0
    Cross Keys HS-A-001 04:bd:88:48:33:90 80:be:05:b4:2d:56 y y 2 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-2ss 6h:3m:53s 1 WAB 33/1
    Cross Keys HS-4-002 04:bd:88:44:36:d1 b0:65:bd:d7:25:04 y y 2 20 airwatch 911 0x103b8 a-HT-20-1ss 6h:8m:38s 1 WAB 4/1
    Cross Keys HS-A-001 04:bd:88:48:33:80 80:be:05:b4:31:a9 y y 19 20 DCSD.Secure 911 0x101c3 g-HT-20sgi-2ss 7m:33s 1 WAB 40/1
    Cross Keys HS-4-002 04:bd:88:44:36:d0 b0:65:bd:e0:1d:6c y y 21 20 DCSD.Secure 911 0x103b7 a-HT-20-1ss 2h:11m:4s 1 WAB 2/1
    Cross Keys HS-A-001 04:bd:88:48:33:90 80:be:05:b1:bf:2b y y 6 20 DCSD.Secure 911 0x101c0 a-HT-40sgi-2ss 7h:31m:31s 15 WAB 11/2
    Cross Keys HS-4-002 04:bd:88:44:36:d0 b0:65:bd:d5:03:7b y y 2 20 DCSD.Secure 911 0x103b7 a-HT-20-1ss 6h:8m:44s 1 WAB 18/5
    Num Clients:127
    Total num of 5G capable clients:126
    Total num of 5G capable clients in 2.4G band:22
    Total num of 5G capable clients in 5G band:104
    Total num of 2.4G only clients:1
  • 6.  RE: show ap association band steer output
    Posted May 13, 2016 04:26 PM
    Quick question, why are you looking to place Air monitors?
  • 7.  RE: show ap association band steer output
    Posted May 14, 2016 02:01 PM
    Rouge Dection
  • 8.  RE: show ap association band steer output
    Posted May 14, 2016 02:16 PM
