"show auth-tracebuf mac" No result
  • 1.  "show auth-tracebuf mac" No result
    Posted Sep 07, 2017 04:01 AM
    Hi ,
    I've enabled user debug for some mac addresses.
    The strange thing is when I'v executing "#show auth-tracebuf mac" , i get no results
    show auth-tracebuf mac 00:17:23:f0:52:bf
    Warning: user-debug is enabled on one or more specific MAC addresses;
    only those MAC addresses appear in the trace buffer.
    Auth Trace Buffer
    (wlc1) #show debug
    DEBUG LEVELS
    Facility Level Debug Value Sub Category Process
    user-debug debugging 00:17:23:f0:52:bf N/A N/A
  • 2.  RE: "show auth-tracebuf mac" No result
    Posted Sep 07, 2017 05:59 AM
    There is not a large buffer for that command.  If you have a busy network, you need to run that command right after that client authenticates, otherwise the logs will wrap.
  • 3.  RE: "show auth-tracebuf mac" No result
    Posted Sep 07, 2017 06:11 AM
    I don't think that's the case because when I run "show auth-tracebuf" I can see records for 2 months ago. don't know why, but seems it stoped working since two months ago
  • 4.  RE: "show auth-tracebuf mac" No result
    Posted Sep 07, 2017 06:17 AM
    You should remove that mac address from the user-debug table and see if you see the auth-tracebuf of any new authentications.
    This is my last guess:  you might have had the clock set wrong for the entry two months ago.
  • 5.  RE: "show auth-tracebuf mac" No result
    Posted Sep 07, 2017 09:00 AM
    After removing mac addresses from user-debug, I could see real-time results for "show auth-tracebuf" , but after adding mac addresses again , same thing happened , no additional results
