Network Management
show interface status - Link-Aggregation
  • 1.  show interface status - Link-Aggregation
    Posted Aug 22, 2019 03:55 AM
    I have question about Link-Aggregation,
    In HP, when you press:  display interface brief, I can see The real speed of the link Aggregation - 2G, But in Aruba I cant see that ,
    Maybe do you know the currect command to see that ? or to see the real speed of the link-aggregation ?
  • 2.  RE: show interface status - Link-Aggregation
    Posted Aug 22, 2019 11:44 AM
    Can you please elaborate on what Aruba product you are trying to see the link aggregation speed for 2G.
  • 3.  RE: show interface status - Link-Aggregation
    Posted Sep 15, 2019 08:09 AM
    2930F Sir.
  • 4.  RE: show interface status - Link-Aggregation
    Posted Sep 15, 2019 08:42 AM
    The 2930F is still HP ProCurve underneath - just updated with Aruba integrations and features - so the commands are still mostly the same.
    This is the output I see from a 2930F switch, with port 25-26 aggregated/trunked. Each port says 10GigFD; the aggregate link is 10+10=20
    2930F-Stn1-Building1SW2(config)# sh int br
     Status and Counters - Port Status
                              | Intrusion                           MDI  Flow Bcast
      Port         Type       | Alert     Enabled Status Mode       Mode Ctrl Limit
      1            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      2            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      3            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      4            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      5            100/1000T  | No        Yes     Up     100FDx     MDIX off  0
      6            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      7            100/1000T  | No        Yes     Up     100FDx     MDIX off  0
      8            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      9            100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      10           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      11           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
      12           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      13           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      14           100/1000T  | No        Yes     Down   1000FDx    NA   off  0
      15           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      16           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
      17           100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
      18           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      19           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
      20           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      21           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
      22           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      23           100/1000T  | No        Yes     Down   1000FDx    Auto off  0
      24           100/1000T  | No        Yes     Down   1000FDx    NA   off  0
      25-Trk1      SFP+DA1    | No        Yes     Up     10GigFD    NA   off  0
      26-Trk1      SFP+DA1    | No        Yes     Up     10GigFD    NA   off  0
      27                      | No        Yes     Down   .               off  0
      28                      | No        Yes     Down   .               off  0
